indigozest Ltd. izKNX Unlimited Software Plugin for HS3
📦 FREE US Shipping on orders of $200+
HS4 users: This plugin was created for HS3 and should run on your HS4 system. However, the setup/config pages are not optimized for use on mobile devices. |
This software plugin is designed to interface HomeSeer 3 with KNX installation using a standard KNX IP interface.
This
- This plugin allows you to have two-way communication between your KNX installation and your HomeSeer setup
- Create HomeSeer devices that correspond to the devices in your KNX installation
- HomeSeer devices will be updated based on status updates from the KNX bus
- Send commands to the KNX bus
