Menu
Cart 0
Aeon Labs Aeotec DSC19103-ZWUS Z-Wave Micro Smart Energy Illuminator - HomeSeer Store
  • $ 41.43
The Aeotec Micro Smart Energy Illuminator G2 is a low-cost Z-Wave dimmer module specifically used to enable Z-Wave command and control (on/off/dim) of existing in-wall switches. It can also report immediate wattage consumption or kWh energy usage over a period of time.
  • Adds Z-Wave Wireless Control to Existing Conventional Wall Switches
  • Supports On - Off - Dim Control
  • For Use with HomeSeer and Other Z-Wave Automation Systems
  • Includes Energy Monitoring Features
The wireless module is powered from the mains supply and is a three-wire design which requires a neutral connection. In the event of power failure, non-volatile memory retains all programmed information relating to the unit’s operating status.
It also is a repeater in the Z-Wave network. Acting as a bridge for communication, it will forward Z-Wave command messages to their destinations if the originating controller is out of range from the destination node.
By taking advantage of the Z-Wave mesh network, commands can be routed to their destination via intermediary “listening” Z-Wave products. Products that are Z-Wave certified can be used and communicate with other Z-Wave certified devices.
Specifications
  • USA: 120V 60Hz input, 300W or 2.5A max output.
  • Micro Smart Energy Illuminator Unit
  • Works with Most 908.42 MHz Z-Wave Networks
Customer Reviews
Based on 2 reviews Write a review
We Also Recommend
