Menu
Cart 0
Aeon Labs Aeotec ZW095-A Z-Wave Home Energy Meter (2nd Edition) - HomeSeer Store
Aeon Labs Aeotec ZW095-A Z-Wave Home Energy Meter (GEN5)
  • $ 93.08
If we reduce the amount of energy we use, we not only save money, but also save the environment. Saving money by using less electricity is only possible if we understand when and where we are consuming electricity. That’s what Aeotec’s Z-Wave Home Energy Meter provides you with – understanding.
Installed in your electric box, the energy meter will monitor the total consumption of electricity used by an entire building. Its intelligent clamps will report that energy use back to your Z-Wave gateway or controller, in watts or kilowatt-hours, and in real time. So you can see how much electricity you really use and when you use it.
  • Monitor the total consumption of electricity used by an entire building
  • Wires into your electric box for improved performance
  • Able to communicate your home’s electricity use to Z-Wave devices up to 300 ft.
  • Z-Wave Plus Certified
Specifications
  • Power: 90-260VAC, 50/60Hz
  • Weatherproof: IP43 rated
  • Range: 24m
  • Certifications: FCC, C-Tick, CE, ROHS
  • Home Energy Meter Unit
  • Two clamps
  • Install Wiring
  • Instructions
  • HS3 with Z-wave plugin
  • The Home Energy Meter connects to mains power in your electricity box, as such a professional electrician is required for a safe installation.
Customer Reviews
We Also Recommend
