{"product_id":"cc-plugins-cc-sysmonpro-software-plugin-for-hs4","title":"CC-Plugins CC-SysMonPro Software Plugin for HS4","description":"\u003ch2 class=\"heading page-heading\"\u003eCC-SysMonPro\u003c\/h2\u003e\n\u003cp\u003eCC-SysMonPRO turns HomeSeer into a monitoring and management console for the computers, storage and network gear on your LAN. A small agent reports CPU, memory, disks, SMART, temperatures, antivirus, pending updates, services and processes, and lets you reboot, run scripts, install Windows updates, and update or remove software without leaving HomeSeer. Everything it reads becomes a device, so any reading can trigger any event you already have.\u003c\/p\u003e\n\u003ch3\u003eMain Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eSMART health per drive, with the failing attribute named.\u003c\/li\u003e\n\u003cli\u003eAntivirus product, real-time state and how old the definitions are.\u003c\/li\u003e\n\u003cli\u003eWindows, Linux and macOS, installed and removed from the plugin's Agents page — no separate installer to walk around the building with.\u003c\/li\u003e\n\u003cli\u003eCPU, memory, disk free, uptime, signed-in user and full hardware inventory.\u003c\/li\u003e\n\u003cli\u003ePending Windows updates, installed from HomeSeer with progress reported back; Linux package updates the same way.\u003c\/li\u003e\n\u003cli\u003eInstalled-software inventory across machine-wide, per-user and Store packages, and what is out of date according to winget — with Update, Update all and Remove.\u003c\/li\u003e\n\u003cli\u003eServices and processes, with start, stop and restart.\u003c\/li\u003e\n\u003cli\u003ePrinters and print queues.\u003c\/li\u003e\n\u003cli\u003eReboot, shut down, run a command, run a saved script.\u003c\/li\u003e\n\u003cli\u003eAn optional screen thumbnail, off by default and off per machine.\u003c\/li\u003e\n\u003cli\u003eSynology (DSM 6\/7) and TrueNAS (CORE\/SCALE): volumes, disks, temperature, packages and containers.\u003c\/li\u003e\n\u003cli\u003eUniFi controllers, devices, clients, ports and firmware.\u003c\/li\u003e\n\u003cli\u003eIP cameras: recording state, storage health and motion.\u003c\/li\u003e\n\u003cli\u003eUPS charge, runtime, battery type and mains state.\u003c\/li\u003e\n\u003cli\u003eA scheduled internet speed test with history and data-use accounting, plus your public address, its carrier and how long it has held.\u003c\/li\u003e\n\u003cli\u003eNetwork discovery: scan a subnet, name what is on it, and be told when something new appears.\u003c\/li\u003e\n\u003cli\u003eA health score for each device and for everything together, from thresholds you set globally or per machine.\u003c\/li\u003e\n\u003cli\u003eAlert rules on any reading, with a duration, a severity and a notification.\u003c\/li\u003e\n\u003cli\u003eTriggers for a reading crossing a line, updates waiting, software out of date, the public address changing, or a machine that stops answering.\u003c\/li\u003e\n\u003cli\u003eActions to reboot, shut down, run a script, install updates or update all software.\u003c\/li\u003e\n\u003cli\u003eEvery reading is published as a HomeSeer device, so the rest of HS4 can use it.\u003c\/li\u003e\n\u003cli\u003eA full asset report: make, model, serial, processor, memory, BIOS and age, operating system, what is installed and whether it is current.\u003c\/li\u003e\n\u003cli\u003eAn installed-software rollup across every machine.\u003c\/li\u003e\n\u003cli\u003eHistory and charts for every reading, with CSV export.\u003c\/li\u003e\n\u003cli\u003eAgents auto-update with plugin updates and can also be uninstalled through Homeseer.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eIncluded\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eSoftware License Codes\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eRequirements\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eHomeSeer HS4-Powered System\u003c\/li\u003e\n\u003cli\u003eCompatible with Windows and Linux\u003c\/li\u003e\n\u003cli\u003eHomeSeer HS4 4.2.0.0 or newer.\u003c\/li\u003e\n\u003cli\u003eThe agent needs .NET Framework 4.6.2 on Windows, or Mono on Linux and macOS.\u003c\/li\u003e\n\u003cli\u003eAgents are reached on TCP 8791 by default, on your own network only.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eLinks\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003ca href=\"https:\/\/forums.homeseer.com\/forum\/hs4-products\/hs4-plugins\/internet-network-plug-ins-aa\/cc-sysmonpro\" target=\"_blank\"\u003eSupport Forum\u003c\/a\u003e\u003cbr\u003e\n\u003c\/li\u003e\n\u003cli\u003e\n\u003ca href=\"https:\/\/docs.homeseer.com\/products\/installing-plugins\" rel=\"noopener\" target=\"_blank\"\u003eHow to install plugins\u003c\/a\u003e\u003ca href=\"https:\/\/docs.homeseer.com\/display\/HS4\/Installing+Plugins\" target=\"_blank\"\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Chris Couture","offers":[{"title":"Default Title","offer_id":50562354512047,"sku":"PI-CCSYSMONPRO-HS4","price":29.95,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1248\/3803\/files\/644_storeimage-500.jpg?v=1790878292","url":"https:\/\/shop.homeseer.com\/products\/cc-plugins-cc-sysmonpro-software-plugin-for-hs4","provider":"HomeSeer","version":"1.0","type":"link"}
