Menu
Cart 0
Cooper RF9501DW Decorator Z-Wave 15 amp Relay Wall Switch, White - HomeSeer Store
  • $ 45.50
  • Sale
The ASPIRE RF 15A switch (RF9501) replaces regular switches or dimmers (where a neutral is present) to provide local and remote ON/OFF control for Incandescent, Magnetic Low-Voltage, Electronic Low-Voltage and Fluorescent lighting loads. Each switch can be manually controlled and remotely controlled by commands sent from an ASPIRE RF controller or other Z-Wave compatible controllers or programs. An ASPIRE RF switch utilizes existing 120 V/AC 60Hz standard house wiring and fits in a standard wallbox. No new wiring is needed.
  • Switch reports its status instantly to HomeSeer
  • Supports the Z-Wave scene class so it can be added to scenes created in HomeSeer or other controllers
  • Complete configuration through Homeseer
Specifications
  • 15 amp max
  • 908.42 MHz
  • RF9501 switch
  • Instructions
Comments / Notes
  • Note: For 3-way (or more) circuits, use Cooper RF9517 accessory switch only.
  • Note: All colors normally ship within 24 hours.
We Also Recommend
