Menu
Cart 0
Cooper RF9517WS Z-Wave Relay Accessory Switch - OPEN BOX - HomeSeer Store
  • $ 42.29
  • Sale
Product Overview
OPEN BOX Color is White
Accessory switch for use with Cooper RF9501 only!
RF transmitter only, it does not control a load
Use it as a companion switch for N-Way circuits
associate this switch with the switch controlling the actual load
Use this switch when you do not need dimming capability, just On and Off
Important Information
ASPIRE RF Accessory Switch (RF9517) replaces regular switches or dimmers to provide local and remote ON/OFF control. The device also provides 3-way, multi-location or virtual 3-way remote ON/OFF control of a selected RF switch without the need for traditional 3-way wiring. Each switch can be manually controlled and remotely controlled by commands sent from an ASPIRE RF controller or other Z-Wave compatible controllers or programs. ASPIRE RF switches utilize existing 120 V/AC 60Hz standard house wiring and fit in standard wallboxes. No new wiring is required.
This switch does NOT control a load directly, it is an RF transmitter and needs to be associated with the RF9501 using either PC software or a Cooper handheld remote. It is used to send RF commands (ON/OFF) to the master RF9501 switch that is connected to the load. If you are unsure as to which switch you need, give us a call.
Specifications
120 V/AC 60Hz
Alpine White Color
Instructions
Spec Sheet
ASPIRE RF information
RF9517 Switch
Install Guide
More Information
Accessory switch for use with Cooper RF9501 only! Will not work with any other Cooper load carrying switch.
Comments / Notes
Note: Alpine White products normally ships within 24 hours. All other colors normally ship within 48 hours.
We Also Recommend
