Menu
Cart 0
Cooper RF9540-NDW White Decorator Z-Wave 3-Way, 3-Wire 600 watt Dimmer - OPEN BOX
  • $ 39.00
  • Sale
Open Box stock includes customer returns that have been opened or new items with damaged packaging. Most items are in 'like new' condition but some may have slight cosmetic blemishes. All open box items come with the original manufacturer's warranty and are also covered by our 30-day return policy.
Product Overview
Designed for use with dimmable incandescant, CFL and LED bulbs
Supports instant status, HomeSeer is immediatly notified when switch is operated locally.
Supports associations, can be associated with HomeSeer or other devices.
Supports Z-Wave scene class so it can be used with wall controllers and HomeSeer scenes.
Dimming bar with LED Brightness indicator
Can be associated with up to 5 different devices
Requires a neutral
Join our GearHouse Club for a 10% Discount on All Cooper Products! call for details: 603-471-2816
Important Information
Aspire RF™ Dimmers replace regular switches to provide local and remote ON/OFF/DIM/BRIGHT control and are compatible with Incandescent, Magnetic Low-Voltage and Electronic Low-Voltage lighting loads (RF9527). Aspire RF Dimmers provide other programmable functions (scenes, events, association, child lockout, etc.) when used with Aspire RF or other Z-Wave® compliant controllers*. Each dimmer can be manually and remotely controlled by commands sent from an Aspire RF controller (RFTDCSG, RFHDCSG, RFBER) or other Z-Wave compatible controllers or programs. Aspire RF Dimmers utilize existing 120 V/AC 60Hz standard house wiring and fit into standard wallboxes. No new wiring needed.
See Specifications PDF for additional information.
Specifications
Max: 600W, incandescent, 300W Dimmable CFL/LED
120 VAC 60Hz
Specifications
Instructions
RF9540-ND Switch
Instructions
More Information
Dimming Wall Switch Comparison
Comments / Notes
Note: For 3-way (or more) circuits, use Cooper RF9542-Z accessory switch only. When using an RF9542-Z it will need to associated with the RF9534-N using either HomeSeer software or a Cooper remote control. The association allows the RF9542-Z to control the RF9534-N using RF control. No traveler wire is used or required.
We Also Recommend
