Menu
Cart 0
Cooper RF9542-ZDS Z-Wave Dimmer Accessory Switch - Desert Sand - HomeSeer Store
  • $ 43.99
Aspire RF™ Accessory Dimmers replace regular switches or dimmers to provide local and remote ON/OFF/DIM/BRIGHT control. The device also provides multi-location control or virtual 3-way remote ON/OFF/DIM/BRIGHT control without the need for traditional 3-way wiring or a dedicated traveler wire. Aspire RF Accessory Dimmers provide other programmable functions (scenes, events, association, child lockout, etc.) when used with Aspire RF or other Z-Wave® compliant controller*. Each dimmer can be manually controlled and remotely controlled by commands sent from an Aspire RF controller (RFHDCSG, RFTDCSG, RFBER) or other Z-Wave compatible controllers or programs. Aspire RF Dimmers utilize existing 120V/AC 60Hz standard house wiring and fit in standard wallboxes. No new wiring is needed.
  • RF transmitter only, it does not control a load
  • Use it as a companion switch for N-Way circuits
  • Simply associate this switch with the switch controlling the actual load
  • Use this switch when you need dimming capability
  • Brightness Indicator LEDs
  • Can be associated with up to 5 devices
Specifications
  • 120 VAC, 60Hz
  • Specifications
  • Instructions
RF9542-Z switch
Instructions
Note that this is an RF accessory switch and it needs to be associated with the primary switch controlling the load. This is done with either the HomeSeer software or a Cooper remote control.
We Also Recommend
