Menu
Cart 0
Cooper RF9542-ZDW Decorator Z-Wave Dimmer Accessory Switch, White - HomeSeer Store
  • $ 48.99
Aspire RF™ Accessory Dimmers replace regular switches or dimmers to provide local and remote ON/OFF/DIM/BRIGHT control. The device also provides multi-location control or virtual 3-way remote ON/OFF/DIM/BRIGHT control without the need for traditional 3-way wiring or a dedicated traveler wire. Aspire RF Accessory Dimmers provide other programmable functions (scenes, events, association, child lockout, etc.) when used with Aspire RF or other Z-Wave® compliant controller*. Each dimmer can be manually controlled and remotely controlled by commands sent from an Aspire RF controller (RFHDCSG, RFTDCSG, RFBER) or other Z-Wave compatible controllers or programs. Aspire RF Dimmers utilize existing 120V/AC 60Hz standard house wiring and fit in standard wallboxes. No new wiring is needed.
  • RF transmitter only, it does not control a load
  • Use it as a companion switch for N-Way circuits
  • Simply associate this switch with the switch controlling the actual load
  • Use this switch when you need dimming capability
  • Brightness Indicator LEDs
  • Can be associated with up to 5 devices
Specifications
  • 120 VAC, 60Hz
  • RF9542-Z switch
  • Instructions
Comments / Notes
  • Note: Alpine White products normally ships within 24 hours. All other colors normally ship within 48 hours
  • Note that this is an RF accessory switch and it needs to be associated with the primary switch controlling the load. This is done with either the HomeSeer software or a Cooper remote control.
We Also Recommend
