Menu
Cart 0
Cooper RF9542DLA Decorator Non-RF Accessory Switch for 2-Wire Dimmers - Light Almond - OPEN BOX - HomeSeer Store
  • $ 18.50
  • Sale
Product Overview
Non-RF accessory switch only; it does not control a load
Use it as a companion switch for N-Way circuits
Compatible with RF9534 and RF9536
Use this switch when you need dimming capability
Brightness Indicator LEDs
No Neutral required
Important Information
Aspire RF™ Accessory Dimmers replace regular switches or dimmers to provide local and remote ON/OFF/DIM/BRIGHT control. The device also provides multi-location control or virtual 3-way remote ON/OFF/DIM/BRIGHT control without the need for traditional 3-way wiring or a dedicated traveler wire. Aspire RF Accessory Dimmers provide other programmable functions (scenes, events, association, child lockout, etc.) when used with Aspire RF or other Z-Wave® compliant controller*. Each dimmer can be manually controlled and remotely controlled by commands sent from an Aspire RF controller (RFHDCSG, RFTDCSG, RFBER) or other Z-Wave compatible controllers or programs. Aspire RF Dimmers utilize existing 120V/AC 60Hz standard house wiring and fit in standard wallboxes. No new wiring is needed.
Specifications
120 VAC, 60Hz
Specifications
Instructions
RF9542 switch
Instructions
More Information
This accessory switch is for use with Cooper 2-wire dimmers only (RF9534 and RF9536). It cannot be used with 3-wire dimmers.
We Also Recommend
