Menu
Cart 0
Dome DMWV1 Wireless Z-Wave Plus Water Main Controller
  • $ 99.99
The Dome Home Automation DMWV1 Water Main Shut-off is designed to fit over existing 1/4 turn ball-valves for pipes sized up to 1 1/2 inches. No professional plumbing contractor is required -- it can be installed by a homeowner with just a screwdriver. This device requires a HomeSeer system or other Z-Wave Certified hub for operation.
  • Easy-to-Install using minimal tools.
  • Installs over existing valve without need of a plumber using just a screw driver.
  • Works with 1/4 turn ball-valves on pipes sized up to 1 1/2 inch.
  • Open/Close valve control allowing for automatic water shut-off when leaks are detected as well as on demand control using your smarthome mobile app.
  • Can be set up to Automatically Shut Valve when water is detected by the leak sensor
  • 120'-150' range depending on the environment, also functions as Z-Wave signal extender.
  • Z-Wave Plus Certified. Requires a Z-Wave Certified Hub to operate.
Specifications
  • Compatible with US Z-Wave networks (908 MHz)
Downloads (Manuals / User Guides / Software) What's Included
  • DMWV1 Unit
  • Mounting Hardware
  • Power Supply
  • Manual
  • HomeSeer HS3 system (or other Z-Wave certified hub) required for full functionality
  • HomeSeer Z-Wave plug-in v3.0.1.103 or higher
Customer Reviews
Based on 2 reviews Write a review
We Also Recommend
