Menu
Cart 0
Fibaro FGFS101 Z-Wave Flood Sensor - HomeSeer Store
  • $ 59.99
The Fibaro FGFS101 Z-Wave water sensor is designed to send wireless Z-Wave commands when water leaks are detected. Use with HomeSeer or other Intellignent Controllers to sound alarms, send notifications or activate Z-Wave devices (like water valves).
  • Z-Wave Water / Leak Detection
  • Easy installation without drilling or wiring.
  • May be installed anywhere Flood Sensor contacts extended with a wire
  • Detect water leaks before it becomes a problem
  • Sends notifications of a threatening flood or a rapid temperature change when connected to a Z-Wave system
  • Compatible with any Z-Wave network controller; Integrates with any traditional alarm system
  • Powered from a single battery that lasts up to 2.5 years
  • Includes Built-in Buzzer
  • Works with HomeSeer and other Z-Wave Home Automation Systems
  • Detects leaks in Kitchens, Bathrooms, Laundry Rooms, Basements, etc
  • Sensor
  • Manual
  • HomeSeer version 3.0.0.0 or later
Customer Reviews
We Also Recommend
