Menu
Cart 0
First Alert ZCOMBO-G Z-Wave Smoke and Carbon Monoxide Detector - HomeSeer Store
  • $ 43.87
The photoelectric Smoke and carbon monoxide Detector is a Z-Wave enabled device which is fully compatible with any Z-Wave enabled network. Z-Wave enabled devices displaying the Z-Wave logo can also be used with it regardless of the manufacturer, and ours can also be used in other manufacturer’s Z-Wave enabled networks.
  • Z-Wave Smoke and Carbon Monoxide Detector
  • Use to Trigger Automation Events with HomeSeer and other systems
  • Use with HomeSeer to turn on lights and shut down HVAC when smoke is detected (requires additional hardware)
Inclusion of this detector on other manufacturer’s Wireless Controller menu allows remote operation of connected modules when the detector is triggered. Z-Wave node in the system also acts as a repeater, so as to re-transmit the RF signal to ensure that the signal is received by its intended destination by routing the signal around obstacles and radio dead spots.
HomeSeer events may be triggered on the following notifications:
  • Alarm Test
  • Alarm Test Silenced
  • Alarm Smoke
  • Alarm Smoke Silenced
  • Alarm CO
  • Alarm CO Silenced
  • Alarm Malfunction
  • Alarm Malfunction Silenced
  • Alarm CO Sensor End of Life
  • Alarm CO Sensor End of Life Silenced
  • Alarm Heartbeat
  • No Notifications
Specifications
  • Z-Wave Frequency: 908.42 MHz (US)
  • Battery Powered (2 AA batteries)
  • Battery Life 2 years**
  • Operating Range 30 meters open space (indoor)
  • Weight: 8.4 oz
  • Operating Voltage: 3V (Two 1.5V AA) Battery Powered
  • Temperature Range: 40°F (4°C) to 100°F (38°C)
  • Humidity Range:10% to 95% relative humidity (RH)
  • Audio Alarm: 85dB at 10 feet
  • ZCOMBO-G Smoke Detector
  • 2 AA batteries
  • Mounting Bracket
  • Mounting Screws
  • User Guide
  • HomeSeer Z-Wave Plug-In Version 3.0.0.217 or Later.
Customer Reviews
Based on 2 reviews Write a review
We Also Recommend
