Menu
Cart 0
Global Cache WF2CC Wifi to Contact Closure Controller - HomeSeer Store
  • $ 117.33
Wirelessly connect, monitor, and control low voltage, wired devices over a network and the Internet. The iTach WiFi devices provide a new level of control flexibility, enabling device networking without wiring. The product is based on open systems and standards for easy integration and compatibility with PC based control software, iPhone/iPod/iPad control apps, and high-end control systems.
  • Allows HomeSeer to Control Contact Closures (Relays) in any Room via Wi-Fi
  • Ultra Compact Design
  • Built-in webserver allows for easy setup
  • 3 Integrated Contact Closure Relays w/ tran­sient volt­age sup­pres­sion
  • Allows for control and monitoring of in-line, low voltage wiring
  • Possibilities include: pools/spas, garage doors, irrigation, etc…
Specifications
  • Screw ter­mi­nal 24V AC/DC@.5A N.O. con­tact
  • Compatible to 802.11b/g
  • Dimensions (LxWxH): 3.25“x2.25“x1.25
  • Weight: 3.25 oz. (6 oz. with power supply)
  • FCC (Part 15, Class B), C-tick, CE, RoHs compliant
  • 5 to 16V DC@300mA (wall power adapter included)
  • 2-year limited warranty
  • GC-WF2CC unit
  • Quick Start Guide
  • AC Power Adapter
  • Wi-Fi enabled Computer (for initial setup)
  • HomeSeer GC100 Plug-in (for use with HomeSeer systems)
Comments / Notes
  • Note: When using with HomeSeer, our Global Cache plug-in version 3.0.0.2 or later is required. Install this plugin from the HomeSeer updater within HomeSeer.
  • This is an output only device, HomeSeer cannot read the status of the relays, only set them.
We Also Recommend
