Menu
Cart 0
GoControl FS20Z-1 Z-Wave Relay Fixture Module:HomeSeer Store
  • $ 36.83
Can be installed above light fixtures in a ceiling box
Max load 20 amps
Functions as an automatic repeater to other Z-Wave devices
The LED on the FS20Z-1 will turn on when the load attached is ON.
Important Information
The FS20Z-1 Isolated Contact Fixture Module. Allows for ON/OFF control of load connected, it does not support dimming. This Isolated Contact Fixture Module is designed to work with other Z-Wave enabled devices. Acts as a repeater for other Z-Wave devices.
The relay on this device is isolated from the power line, so it can be used to switch any load, including low voltage types.
Specifications
Power: 120 VAC, 50/60 Hz
908.42 MHz signal
FS20Z-1 Module
Customer Reviews
We Also Recommend
