Menu
Cart 0
GoControl LB60Z-1 Z-Wave Dimmable LED Light Bulb 5-Pack
  • $ 60.00
The LinearLinc/GControl LB60Z-1 Bulb is a dimmable Z-Wave Plus LED light bulb for use with HomeSeer (and other) home automation systems. The bulb allows convenient remote control of your lighting without rewiring or other electrical work.
  • Dimmable LED light bulb for use with HomeSeer (and other) systems
  • Automate lighting without rewiring or electrical work
  • Fully dimmable, instant-on bulb
  • 750 Lumens (equivalent to 60-watt incandescent bulb)
  • Consumes just 9 watts
  • Functions as a Z-Wave network repeater
  • Z-Wave Plus Technology
Suggested Uses
  • Use in place of a Z-Wave lamp module in any application. Allows same on-off-dim control without ugly plug-in modules cluttering up your home.
  • Add smart light control with no wiring; great for apartment dwellers!
  • No neutral at switch location? No problem! Install LB60Z bulbs in overhead fixture and pair with WA00Z-1 wall controller.
  • Add smart light control to any pull chain light fixure. Great for closets!
Specifications
  • 120v/60hz White
  • Signal (Frequency): 908.42 MHz, 9.6Kbps or 40Kbps capable
  • 750 lumens
  • 9 watts power consumption
  • 2700K color temperature (warm white)
  • Z-Wave Plus certified
  • (5) LB60Z-1 light bulbs
  • Installation guide
  • Note: Packaging/branding may be either "GoControl" or "Linear".
Customer Reviews
Based on 10 reviews Write a review
We Also Recommend
