Menu
Cart 0
GoControl WI15VZ-1 Z-Wave Irrigation Controller
  • $ 69.95
THIS PRODUCT IS DISCONTINUED AND IS SOLD OUT
The GoControl WI15VZ-1 is a Z-Wave actuated 15 zone irrigation controller that works with all HomeSeer software and controllers.
The WI15VZ-1 allows you to take charge of your sprinkler and landscape watering usage, saving money and water.
IMPORTANT: This product only works with HomeSeer systems. It is NOT compatible with SmartThings, Wink or Vera hubs! See Comments / Notes section below for other limitations and issues.
  • May be used with HomeSeer to remotely (and automatically) control up to 15 irrigation zones - 1 at a time.
  • Simple push-down terminals for valve connections (no tools required).
  • Includes valve-fault detection (shuts off valve if broken sprinkler head is sensed).
  • Designed to fit into most existing or new exterior-grade sprinkler timer cabinets, or directly on an interior wall.
  • Works with most 24 VAC residential irrigation valve systems.
  • Z-Wave Plus certified.
  • Power: 120 VAC,, 60 Hz Input, 18VDC 1A Output
  • Signal (Frequency): 908.42 MHz
  • Wireless Range: Up to 130 feet line of sight
  • 32 to 158°F (0 to 70°C)
  • Manual (See Comments on Requirements Tab for Corrections)
  • WI15Z-1 Irrigation Controller
  • Power Supply
  • Manual
  • Works ONLY with HomeSeer HS3 systems
  • HomeSeer Z-Wave Plug-in v3.0.1.95 or later
Comments / Corrections to the Manual
  • Master valve feature is not supported.
  • External sensors are not supported.
  • Stand-alone sprinkling times are limited to 5, 10, 20, 30 & 60 minutes. If other times are required, create schedules and intervals using HomeSeer.
  • GoControl does not provide technical support for this product.
  • This controller does not include on-board scheduling features. It responds to commands from HomeSeer systems.
Customer Reviews
Based on 14 reviews Write a review
