1 of 2
HomeSeer DS100 G8 Z-Wave Long Range Door / Window Sensor (BWP)
Regular price $ 39.00 USD
Out of stock
Z-Wave Door / Window Sensor
Our Z-Wave door & window sensor alerts your smart home hub when doors or windows are opened & closed. DS100 G8 works with standard or long range Z-Wave, supports S2 security, is easy to set up, takes regular AAA batteries and comes with all the hardware you need to install quickly. Works with most popular smart hubs.
  • Door / window sensor
  • Uses conventional AAA batteries for easy battery changes
  • Supports Z-Wave Plus and Z-Wave LR (long range) technologies
  • Supports S2 Security
  • Small and Sleek design
Operation
Install the sensor on a door or window using the supplied hardware. Then pair it to your smart software or hub. A Z-Wave command will be broadcast every time the sensor is triggered. Battery status will also be updated daily.
  • Power: (2) AAA batteries
  • US Z-Wave Operation
  • Z-Wave Plus Certified
  • DS100 G8 Sensor Body
  • Magnet Piece
  • Double stick tape
  • Mounting screws
  • (2) AAA alkaline batteries
  • Manual
Important
  • Requires US Z-Wave network
  • If you're using version 4 of the Z-Wave plugin, you will need 4.0.1.0 or later.
  • Compatible with HomeSeer, Home Assistant, Hubitat hubs
