Cart 0
HomeSeer Easy Starter Kit 2
  • $ 255.80
  • Sale
Our "Easy Starter Kit" is the fast and easy way to get into DIY home automation! This kit includes our popular HomeTroller Zee S2 home controller and this mixture of easy to install Z-Wave Plus sensors and lighting products: HS-MS100+ motion sensor, HS-LS100+ leak sensor, HS-PA100+ plug-in switch and GoControl LB60 smart bulb.
HomeTroller Zee S2 Main Features
  • Includes locally-managed HS3-Pi3 Software for faster, safer and more reliable performance!
  • Compatible with IFTTT
  • Compatible with Amazon Alexa voice assistants (Echo & Dot)
  • Compatible with Google Home voice assistants
  • Z-Wave Plus Technology for better performance and greater range
  • Includes Free MyHS Remote Access Service and mobile apps for iOS and Android devices
  • Supports Your Choice of Up to 5 Linux Plug-ins (Drivers) including Z-Wave, Zigbee, Insteon and much more (browse plug-ins)!
HomeTrollers process all your automation locally, ensuring the highest level of reliability and performance. You won't experience the "delays" that are common with Internet-reliant solutions like typical 'smart hubs' and 'gateways'.
Safe & Secure
Every HomeTroller is designed to store all your sensitive information right there at home, never in the cloud. This helps to prevent hackers and prying eyes from seeing your personal data and custom home automation schedules.
Our MyHS web service simplifies the process of controlling your home remotely but is not required to automate your home. Your HomeTroller will continue to control your home 24/7, even when the internet is down or there's a web service outage.
HomeTrollers are designed to work with thousands of products from hundreds of manufactures using most popular home automation technologies. With HomeSeer, your imagination is your only limitation!
Amazon Echo / IFTTT / Google Home
Leverage the latest technology with your HomeSeer-powered home! Use Amazon's popular 'Echo' or a Google Home device to control your home by voice and create IFTTT 'Recipes' that integrate with more than 300 web products, apps and services from around the world!
Zee S2 Specifications
  • CPU: Quad-core 1.2 GHz
  • RAM: 1 GB | Storage: 8 GB SD
  • 4 USB Ports | LAN Port | HDMI Port
  • Includes built-in Z-Wave Plus certifed interface (US) | Built-in WiFi
  • Works with your choice of up to 5 software plug-ins (drivers)
Downloads(Manuals / User Guides / Software)
  • HomeTroller Zee S2 (US)
  • HS-PA100+ Z-Wave Plug-in Switch
  • HS-MS100+ Z-Wave Motion Sensor
  • HS-LS100+ Z-Wave Leak Sensor
  • GoControl LB60 Z-Wave Smart Bulb
  • Internet Connected Router
Customer Reviews
Based on 17 reviews Write a review
We Also Recommend
