Menu
Cart 0
HomeSeer HomeTroller S6 Home Automation Controller + Z-NET (US)
  • $ 899.95
  • Sale
Hometroller S6 Is Our Ultimate Home Controller. It Combines The Speed & Reliability Of Locally Managed Automation With The Power Of Cloud-Managed Services. Hometroller S6 Is Powered By HS3 Home Automation Software, Includes An Industrial Grade Chassis And Has Enough Ports To Satisfy Virtually Any Automation Need.
  • Smart Home Controller with HS3  Software
  • Fast, Secure & Reliable Locally Processed Automation
  • Compatible with Hundreds of Products and Technologies
  • Works with Amazon Echo & Google Home Voice Assistants
  • IFTTT Compatible - Works with Hundreds of Web Products, Apps and Services
  • Includes Z-NET Z-Wave Plus Interface ($149.95 Value)!
HomeTrollers process all your automation locally, ensuring the highest level of reliability and performance. You won't experience the "delays" that are common with Internet-reliant solutions like 'smart hubs' and 'gateways'..
Safe & Secure
Every HomeTroller is designed to store all your sensitive information right there at home, never in the cloud. This helps to prevent hackers and prying eyes from seeing your personal data and custom home automation schedules.
Internet-Independent
Our MyHS web service simplifies the process of controlling your home remotely but is not required to automate your home. Your HomeTroller will continue to control your home 24/7, even when the internet is down or there's a web service outage.
HomeTrollers are designed to work with thousands of products from hundreds of manufactures using most popular home automation technologies. With HomeSeer, your imagination is your only limitation!
Amazon Echo / IFTTT / Google Home
Leverage the latest technology with your HomeSeer-powered home! Use Amazon's popular 'Echo' or a Google Home device to control your home by voice and create IFTTT 'Recipes' that integrate with more than 300 web products, apps and services from around the world!
Specifications
  • Embedded Control Software: HomeSeer HS3
  • Operating System: Windows 10
  • Processor: Intel Celeron 3205U CPU (1.5 GHz, 2 core)
  • Memory: 2 GB RAM
  • Storage: 32 GB SSD
  • Ports: (2) RS232, (6) USB, Mic in/Line out, (2) 10/100/1000 LAN, HDMI, Display Port
  • Power Consumption: Less than 15 watts (nominal)
  • Dimensions: 8"w x 6.5"d x 1.5"h
  • Power Supply: Universal 120-240v, 50/60Hz (US plug)
  • Certifications: UL, CE, RoHS
Downloads(Manuals / User Guides / Software)
  • HomeTroller S6 Unit w/embedded HS3
  • HomeSeer Z-NET (US) Interface
  • Mounting Feet
  • Wall Mount Bracket
  • Ethernet Cable
  • Universal Power Adapter
  • Power Cord (with US plug)
Customer Reviews
Based on 2 reviews Write a review
We Also Recommend
