{"product_id":"homeseer-hs-fs100-l-z-wave-indicator-light-sensor-no-box","title":"HomeSeer FS100-L Z-Wave Dual Sensor \u0026 Buzzer (CLEARANCE)","description":"\u003ch2 data-mce-fragment=\"1\"\u003eZ-Wave Dual Smart Sensor\u003c\/h2\u003e\n\u003cp data-mce-fragment=\"1\"\u003eWant to turn your regular 'dumb' appliances into smart ones? HS-FS100-L is a Z-Wave light sensor that's designed to report back to your smart home hub when indicator lights turn on, turn off or change color. Use to monitor dehumidifiers, water softeners, washers, dryers and much more!\u003c\/p\u003e\n\u003cp data-mce-fragment=\"1\"\u003eHS-FS100-L also includes a built-in temperature sensor and buzzer. Use it anywhere you wish to monitor the temperature and\/or issue audible alerts for anything that happens in your home.\u003c\/p\u003e\n\u003ctable border=\"0\" cellspacing=\"0\" cellpadding=\"4\" width=\"100%\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd bgcolor=\"#F5F5F5\"\u003e\n\u003cp\u003e\u003cspan color=\"#2B90D1\"\u003e\u003cspan color=\"#666666\"\u003e\u003cstrong\u003eClearance Stock\u003c\/strong\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cspan color=\"#2B90D1\"\u003e\u003cspan color=\"#666666\"\u003e\u003cspan\u003e\u003cstrong\u003eNo Box\u003c\/strong\u003e items are in like new condition and have been individually tested for full functionality.\u003c\/span\u003e\u003c\/span\u003e\u003c\/span\u003e\u003cspan color=\"#2B90D1\"\u003e\u003cspan color=\"#666666\"\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/span\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cspan color=\"#2B90D1\"\u003e\u003cspan color=\"#666666\"\u003e\u003cspan\u003eBecause these are no longer manufactured, they come with no warranty but are covered by our 30-day return policy.\u003c\/span\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3\u003e\n\u003cbr\u003eMain Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eIndicator Light Sensor\u003c\/li\u003e\n\u003cli\u003eTemperature Sensor\u003c\/li\u003e\n\u003cli\u003eZ-Wave\u003cspan\u003e \u003c\/span\u003econtrollable\u003cspan\u003e \u003c\/span\u003ebuzzer while connected to a power adapter\u003c\/li\u003e\n\u003cli\u003eActs as a Z-Wave repeater when used with \u003ca href=\"https:\/\/shop.homeseer.com\/products\/micro-usb-power-adapter\"\u003eoptional Micro USB power adapter\u003c\/a\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eSuggested Uses\u003c\/h3\u003e\n\u003cp\u003eThink of all the things in your home that have indicator lights. Wouldn't it be great if you could keep track of them even when you're not at home? Now you can! Our new indicator light sensor monitors these lights and reports changes back to your smart home system or hub. Here are just a few things you can do with HS-FS100-L:\u003c\/p\u003e\n\u003ch4\u003eReceive notifications when a...\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eDehumidifier needs to be emptied\u003c\/li\u003e\n\u003cli\u003eHumidifier needs to be filled\u003c\/li\u003e\n\u003cli\u003eWater softener needs more salt\u003c\/li\u003e\n\u003cli\u003eWashing machine turns off\u003c\/li\u003e\n\u003cli\u003eDryer\/Washer turns off\u003c\/li\u003e\n\u003cli\u003eComputer or network equipment needs attention\u003c\/li\u003e\n\u003cli\u003eHome entertainment gear turns on or off\u003c\/li\u003e\n\u003cli\u003eSecurity panel lights come on\u003c\/li\u003e\n\u003cli\u003eHeating or cooling equipment need attention\u003c\/li\u003e\n\u003cli\u003eThe freezer has stopped working, IE: unplugged\u003c\/li\u003e\n\u003cli\u003eAir filter needs replacing\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eVideo\u003c\/h3\u003e\n\u003cp\u003e\u003ciframe height=\"315\" width=\"560\" src=\"https:\/\/www.youtube.com\/embed\/oHQ4-I2q8T8\"\u003e\u003c\/iframe\u003e\u003c\/p\u003e\n\u003ch3\u003eSpecs\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003ePower: Requires 3 AAA batteries or \u003ca href=\"https:\/\/shop.homeseer.com\/products\/micro-usb-power-adapter\"\u003emicro USB adapter (not supplied)\u003c\/a\u003e\n\u003c\/li\u003e\n\u003cli\u003eUS Z-Wave Operation\u003c\/li\u003e\n\u003cli\u003eZ-Wave Plus Certified\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eDownloads\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003e\u003ca href=\"https:\/\/docs.homeseer.com\/products\/hs-fs100\"\u003eAll Documentation\u003c\/a\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eIncluded\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eSensor Body\u003cbr\u003e\n\u003c\/li\u003e\n\u003cli\u003eIndicator light cable with double-stick tape\u003cbr\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eRequirements\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eUS Z-Wave network\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eImportant\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eNot compatible with SmartThings\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"HomeSeer","offers":[{"title":"Default Title","offer_id":44225425146031,"sku":"HS-FS100-L-NB","price":39.97,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1248\/3803\/files\/HS-FS100-L2-1000.jpg?v=1776181679","url":"https:\/\/shop.homeseer.com\/products\/homeseer-hs-fs100-l-z-wave-indicator-light-sensor-no-box","provider":"HomeSeer","version":"1.0","type":"link"}
