Menu
Cart 0
HomeSeer HS-FS100-W Z-Wave Perimeter Water Sensor
  • $ 34.95
  • BLACK MAY
HS-FS100-W is a water sensor that's designed to detect leaks with a special fluid sensing cable. It will send Z-Wave commands when water is detected and when water has not been detected for some time.
Most water sensors (including our HS-LS100+) can only sense fluid in one small spot. HS-FS100-W is designed to check for leaks over a much larger area. Wrap the included 4 ft cable around your water heater or string several cables together to monitor a wall or room.
Video
  • Sensor Body
  • Mounting hardware
  • 4 foot fluid sensing cable
  • Manual
Important
  • US Z-Wave network
Comments / Notes
  • Compatible with HomeSeer systems or with SmartThings hubs (with special device handler).
Customer Reviews
Based on 4 reviews Write a review
