HomeSeer HS-MS100+ G2 Z-Wave Plus Motion Sensor - OPEN BOX
Z-Wave Smart Motion Sensor
HS-MS100+ is a compact, easy to install Z-Wave Plus smart motion sensor that's designed to report to your smart home hub when motion is sensed or when motion has not been sensed for a period of time. Use to track occupancy or monitor for security.
- Motion sensor
- Magnetic mount
- Easy to install
- Easy to adjust
- Works with most Z-Wave certified controllers*
- Works on battery power or line power (adapter not included)
Operation
Install using the supplied hardware and pair with your smart home software or hub. HS-MS100+ may be used to trigger events ("automations") when motion is sensed. Use this turn on lights, send notifications, sound alarms or change the occupancy status of your home. This motion sensor will send Z-Wave commands when (a) motion is sensed and (b) when motion has not been sensed for a (user-adjustable) period of time.
Video
- 908 MHz Z-Wave frequency
- Dimensions (main unit): 2" x 2" x 1.75"
- Micro USB port (for line power)
- Blue LED indicator
- Motion sensor
- CR123a battery
- Mounting hardware
- User guide
- Z-Wave certified home controller or hub
Important
- The vibration sensor is a movement sensor which alerts Z-Wave if the main unit has been moved.
- *This sensor should be compatible with any hub that supports the Z-Wave notification command class. It will not work with hubs that do not support this command class (including Wink).
Condition
Open Box stock includes customer returns that have been opened or new items with damaged packaging. Most items are in 'like new' condition but some may have slight cosmetic blemishes. All open box items come with the original manufacturer's warranty and are also covered by our 30-day return policy. |
Customer Reviews
Based on 1 review
Write a review
