Menu
Cart 0
HomeSeer HS-WA100+ Companion Switch 5-Pack
  • $ 87.20
  • Black Friday Sale
HS-WA100+ is a wired (non-RF) 3-way wall companion switch that provides remote control of HomeSeer load controlling wall switches (HS-WS100+, HS-WD100+). HS-WA100+ is designed to be wired directly to the HS-WS100+ or HS-WD100+ using a "traveler" wire.
  • Wired (non-RF) 3-way companion switch for use with HomeSeer Wall Dimmers & Switches
  • Supports ON - OFF - DIM functions of the connected load switch or dimmer
  • Supports Multi-Tap event triggers of the connected load switch or dimmer
  • May be paired with 1 or 2 more HS-WA100+ companions for 4-way or 5-way operation
  • Easy 'screw terminal' installation
  • Note: HS-WA100+ is not a stand alone switch and will not control a load by itself
Operation
Once installed, HS-WA100+ works like any other paddle-style switch and will remotely control the attached HS-WS100+ or HS-WD100+ load switch with on-off-dim functions. Additionally, the HS-WA100+ will access the built-in features of HomeSeer load switches including the following:
  • Press top or bottom of paddle once - prompts appropriate load switch to turn attached load on or off
  • Press top or bottom of paddle multiple times (2-taps, 3-taps, 4-taps*, 5-taps*) - prompts appropriate load switch to trigger multiple different HomeSeer events.
    *Note: 4-tap & 5-tap triggers only work with 200 series dimmers & switches (HS-WD200+, HS-WS200+)
  • Press & hold top or bottom of paddle - prompts appropriate load switch to dim attached load up or down and may also be used to trigger two more different HomeSeer events
Specifications
  • Compatible with HomeSeer HS-WS100+ and HS-WD100+
  • 120 VAC, 60Hz
  • cUL certified
  • May be paired with 1 or 2 other HS-WA100+ companions for 4-way and 5-way operation
  • Color: White. Almond color kit available
Important Information
This is not a stand-alone switch and will not control a load directly!
  • Five HS-WA100+ wall companions
  • User Guide
  • Wall plates are NOT included
  • Requires standard 3-way electrical wiring (with traveler wire)
  • Must be used with HomeSeer HS-WS100+ or HS-WD100+ wall switches or dimmers
Accessories
Customer Reviews
Based on 2 reviews Write a review
We Also Recommend
