Menu
Cart 0
SPECIAL BUY - HomeSeer HS-WD100 Z-Wave Plus Scene-Capable Smart Dimmer
  • $ 39
  • 🔥 SALE
📦 FREE Shipping on orders of $200+
Z-Wave Smart In-wall Dimmer Switch
HS-WD100+ works with most smart hubs and is compatible with a wide variety of bulbs. The switch may also be used to trigger scenes and automations by multi-tapping the paddle 2 or 3 times.
SPECIAL BUY: This is a limited quantity, special buy item in non-retail packaging. Includes 1-year warranty and 30 day satisfaction guarantee.
  • Handles dimmable bulbs up to 600 watts.
  • Support multi-tap and press & hold event triggers up to 3 taps (8 possible triggers)
  • Supports instant status when controlled locally
  • Compatible with HomeSeer (and many other) smart hubs
  • Supports S2 Security
  • Works with Alexa and Google Home (hub required)
  • Easy 'screw terminal' installation
  • Works with HS-WA100+ wall companion for 3-way, 4-way and 5-way circuits
  • Includes Z-Wave signal repeater feature
Operation
Configure as a dimmer for bedrooms, family rooms and other areas where dimmed lighting is preferred. Once installed, HS-WD100 works like any other dimmer. However, add it to any HomeSeer system (or other compatible hub) and you'll unleash these advanced features!
Multi-tap Triggers
  • Press top or bottom of paddle once - turns attached load on or off and can also trigger  2 HomeSeer events
  • Press & hold top or bottom of paddle - dims attached load and can also trigger 2 HomeSeer events
  • Press top or bottom of paddle 2 or 3 times - triggers up to 4 more different HomeSeer events
  • Compatible with US Z-Wave networks (908 MHz)
  • 120 VAC, 60Hz
  • Max Load: 600 watt incandescent
  • Max Load: 150 watt LED / CFL
  • Operating Temps: 0℃ - 40
  • Supports Z-Wave Plus features
  • Supports Z-Wave S2 security
  • cUL, FCC, Z-Wave Plus certified
  • Forward Phase
  • Color: White. Almond color kit available.
  • HS-WD100 wall dimmer
  • Basic User Guide
  • Screwless wall plate is NOT included
  • Unit will be shipped in plain brown box
  • Z-Wave Core plugin v3.0.9.0 or later
Accessories
Warranty Information
  • 1-year warranty
Customer Reviews
