Menu
Cart 0
HomeSeer HS-WS100+ Z-Wave Plus Smart Switch 5-Pack
  • $ 174.62
  • Black Friday Sale
HS-WS100+ is a Z-Wave Plus certifed relay (on-off) wall switch for use with most lighting and appliance loads. The switch includes the newest 500 series Z-Wave module and is Z-Wave Plus certified to ensure support for the latest Z-Wave features. HS-WS100+ may be used with most home controllers but should be used with HomeSeer Hometrollers for best compatiblity with all features.
  • Supports wireless on-off control of lighting and appliance loads
  • Z-Wave Plus certified for easy inclusion and reliable communications
  • Compatible with HomeSeer (and many other) home controllers
  • Includes double-tap, triple-tap, press & hold event features to trigger up to 6 different home automation events
  • Supports Z-Wave central scene technology
  • Supports instant status when controlled locally
  • Easy 'screw terminal' installation
Operation
Once installed, HS-WS100+ works like any other paddle-style switch and will turn the attached load on or off. However, add it to any HomeSeer system and you'll be able to trigger up to 6 different events!
Press top or bottom of paddle once - turns attached load on or off
Press top or bottom of paddle twice (double-tap) - triggers two different HomeSeer events
Press top or bottom of paddle three times (triple-tap) - triggers two more different HomeSeer events
Press & hold top or bottom of paddle - triggers two more different HomeSeer events
Specifications
  • Compatible with US Z-Wave networks (908 MHz)
  • 120 VAC, 60Hz
  • 900 watt incandescent
  • 200 watt LED / CFL
  • 1/2 HP motor
  • 1800 watts (15 amp) resistive
  • Supports Z-Wave Plus features
  • cUL, FCC, Z-Wave Plus certified
  • Color: White. Almond color kit available.
Important Information
HS-WD100+ and HS-WS100* provide instant status feedback and double-tap, triple-tap, press & hold functionality using the Z-Wave "central scene" command class. The feature is supported by all HomeSeer systems, including HS3 software and HomeTroller controllers. If you're using another brand of controller, be sure to check with that manufacturer to see if the central scene features are supported.
  • Five HS-WS100+ wall switches
  • User Guide
  • Wall plates are NOT included
  • Z-Wave plug-in v3.0.1.66 or higher
Accessories
Customer Reviews
Based on 9 reviews Write a review
We Also Recommend
