Menu
Cart 0
HomeSeer HS-WV100+ Z-Wave Plus 1" Water Valve Controller
  • $ 249.80
  • SALE
HS-WV100+ is a Z-Wave Plus certifed water valve control system that may be remotely or automation controlled to mitigate water damage when leaks are detected. This water valve controller may also be used to regulate water usage and to control irrigation equipment.
  • Wireless Z-Wave enabled water valve control system
  • Use with HomeSeer (and other) home automation systems to remotely and/or automatically control the flow of water
  • Use with water sensors to automatically shut water off when leaks are detected
  • Use to regulate water usage for outdoor spigots, showers, sinks or irrigation equipment
  • Valve includes manual override
Specifications
  • Compatible with US Z-Wave networks (908 MHz)
  • Valve circulation medium: Fluid, Air
  • Valve body material: Stainless steel
  • Valve life expectancy: 70,000 activations
  • Valve maximum working pressure: 1.0MPa
  • Valve max. torque force: 2 Nm
  • Valve operating voltage: DC12V
  • Valve working current: ≤ 500MA
  • Valve open/close time: ≤ 5 Sec
  • Valve environment temperature -15°C~50°C
  • Valve liquid temperature range: 2°C~90°C
  • Valve protection class: IP67
  • Valve safety certification: NSF
  • HS-WV100+ water valve controller
  • 1" electronically activated water valve
  • User Guide
Customer Reviews
We Also Recommend
