Menu
Cart 0
HomeSeer HS-WX300 R2 ($39 with coupon: SPECIAL)
  • $ 59
📦 FREE US Shipping on orders of $200+
SPECIAL BUY - Limited Quantities
Use coupon code SPECIAL to save $20. May not be combined with any other offers or discounts. Free US shipping on orders $200 or more. Limited quantities.
The Best Z-Wave Smart Dimmer Switch
What makes our Z-Wave smart dimmer switch better? HS-WX300-R2 can be configured to run as a dimmer or switch, works with or without a neutral wire, has (7) LED indicators that may be programmed to glow or blink different colors when things happen in your home and you can launch automations by tapping the paddle multiple times.
  • Versatile: May be configured to work as DIMMER or ON-OFF switch
  • Compatible: Does NOT require a neutral wire | perfect for older homes
  • Annunciation: Includes 7 individually controllable RGB LED dimmer status indicators | Color & blink status of LED indicators are controlled with Z-Wave commands
  • Scene Controler: Support multi-tap and press & hold event triggers up to 5 taps (14 possible triggers)
  • Supports instant status when controlled locally
  • Compatible with HomeSeer (and many other) home controllers
  • Supports S2 Security
  • Works with Alexa and Google Home (hub required)
  • Easy 'screw terminal' installation
  • Works with HS-WA100+ wall companion for 3-way, 4-way and 5-way circuits
  • Includes Z-Wave signal repeater feature
Latest Features
the following features were added with firmware v1.13.6
  • Smart bulb feature decouples load control and allows the WX300 to be used exclusively as a controller.
  • Paddle toggle feature allows any paddle press (top or bottom) to be used to turn lights on and off. This feature provides easier manual operation for users with accessibility issues.
  • Default dim level feature allows users to set the dim level that the switch goes to when turned on via the paddle.
  • LED indicator light level feature allows users to change the indicator light intensity.
Videos
Operation
Configure as an ON-OFF switch for bathrooms, kitchens, outdoor lighting and more. Configure as a dimmer for bedrooms, family rooms and other areas where dimmed lighting is preferred. Once installed, HS-WX300 works like any other switch or dimmer. However, add it to any HomeSeer system and you'll unleash these advanced features!
RGB LED Indicators
In normal mode, LED indicators glow to reflect the on/off/dim status of each circuit using a palette of 7 possible colors. Normal mode colors can be set once and left or can be programmed to change every day or on holidays, birthdays and other special events. For example, you can program dimmers to glow green and red on holidays
In status mode, individual LEDs can be controlled to reflect the status of nearly anything in the home. For example, if it's after midnight and the garage door was left open, the 3rd LED on all the bedroom dimmers can be programmed to glow yellow (or any color). If a smoke alarm goes off, all LEDS on all dimmers can blink red. If no status conditions are active, wall switches automatically return to normal mode.
Multi-tap Triggers
  • Press top or bottom of paddle once - turns attached load on or off and can also trigger  2 HomeSeer events
  • Press & hold top or bottom of paddle - dims attached load and can also trigger 2 HomeSeer events
  • Press top or bottom of paddle 2, 3, 4, or 5 times - triggers up to 8 more different HomeSeer events
  • Compatible with US Z-Wave networks (908 MHz)
  • 120 VAC, 60Hz
  • Max Load: 600 watt incandescent
  • Max Load: 300 watt LED / CFL
  • Min Load: 24W (0.2A)
  • Operating Temps: 0℃ - 40
  • Supports Z-Wave Plus features (800 series)
  • Supports Z-Wave S2 security
  • cUL, FCC, Z-Wave Plus certified
  • Forward Phase
  • Color: White. Almond color kit available.
  • IMPORTANT: This switch is designed to control LED, CFL and incandescent lighting loads. It is not designed to control fans, pumps, fluorescent fixtures or other non-lighting loads.
  • Z-Wave Core plugin v3.0.9.0 or later
Compatibility
This switch includes advanced features that are supported by the following hubs:
Accessories
Return Information
  • 2-year warranty
Customer Reviews
No reviews yet Write a review
