Menu
Cart 0
HomeSeer Premium Starter Kit
  • $ 662.80
  • Sale
Our "Premium Starter Kit" strikes the perfect balance of performance and value. This kit includes our popular HomeTroller-SEL home controller, our SmartStick+ Z-Wave Plus USB interface and a mixture of these easy to install Z-Wave Plus sensors and lighting products: (1) HS-WD100+ wall dimmer, (1) HS-WS100+ wall switche, (2) HSM200 multisensors, (2) HS-PA100+ plug-in switches, (2) HS-DS-100+ door sensors and (2) GoControl LB60 smart bulbs.
HomeTroller-SEL Main Features
  • Includes locally-managed HS3 Software for faster, safer and more reliable performance!
  • Compatible with IFTTT
  • Compatible with Amazon Alexa voice assistants (Echo & Dot)
  • Compatible with Google Home voice assistants
  • HS3Touch Designer Mobile App Design Software
  • Z-Wave Plus Technology for better performance and greater range
  • Includes Free MyHS Remote Access Service and mobile apps for iOS and Android devices
  • Supports All Linux Plug-ins (Drivers) including Z-Wave, Zigbee, Insteon, X10 and much more!
HomeTrollers process all your automation locally, ensuring the highest level of reliability and performance. You won't experience the "delays" that are common with Internet-reliant solutions like typical 'smart hubs' and 'gateways'.
Safe & Secure
Every HomeTroller is designed to store all your sensitive information right there at home, never in the cloud. This helps to prevent hackers and prying eyes from seeing your personal data and custom home automation schedules.
Internet-Independent
Our MyHS web service simplifies the process of controlling your home remotely but is not required to automate your home. Your HomeTroller will continue to control your home 24/7, even when the internet is down or there's a web service outage.
HomeTrollers are designed to work with thousands of products from hundreds of manufactures using most popular home automation technologies. With HomeSeer, your imagination is your only limitation!
Amazon Echo / IFTTT / Google Home
Leverage the latest technology with your HomeSeer-powered home! Use Amazon's popular 'Echo' or a Google Home device to control your home by voice and create IFTTT 'Recipes' that integrate with more than 300 web products, apps and services from around the world!
HomeTroller-SEL Specifications
  • CPU: Dual-core Celeron 1.5 GHz
  • RAM: 2 GB | Storage: 32 GB SD
  • 3 USB Ports | LAN Port | HDMI Port
  • Built-in WiFi
  • Works with your choice of Linux software plug-ins (drivers)
Downloads(Manuals / User Guides / Software)
  • HomeTroller-SEL Home Controller
  • SmartStick+ USB Z-Wave Interface
  • HS-WD100+ Wall Dimmers
  • HS-WS100+ Wall Switches
  • 2 HS-PA100+ Z-Wave Plug-in Switches
  • 2 HS-DS100+ Z-Wave Door Sensors
  • 2 HSM200 Z-Wave Multisensors
  • 2 GoControl LB60 Z-Wave Smart Bulbs
  • Internet Connected Router
Customer Reviews
We Also Recommend
