Menu
Cart 0
HomeSeer Z-NET Lite Remote Z-Wave Interface (US)
  • $ 95.96
  • FALL SALE
Network-Connected Z-Wave Controller
Z-NET is a network-connected Z-Wave controller that's designed to send & receive Z-Wave commands from HomeSeer smart home software & hubs. Z-NET is the idea solution for improved performance in large homes or properties with outbuildings (like pool houses or barns)! Works with all HomeSeer systems.
  • Remote Z-Wave Interface for use with HomeSeer Software and HomeTrollers
  • Supports Z-Wave Plus (and older) Products
  • Ethernet Connection Allows for Optimal Positioning in Home
  • WiFi is not included but is available with optional adapter (sold separately)
  • Supports Network Wide Inclusion (NWI) for Easy Product "Pairing"
  • May be Used with Other Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
  • Includes Highly Optimized Antenna for Superior Range and Performance
  • Includes Easy to Use Web-Based Management Features
  • Provides Easy Upgrade Path from Z-Trollers, Z-Sticks, SmartSticks and Most Other Z-Wave Interfaces
  • Case Includes Keyhole slots for wall mounting (with your hardware)
  • Z-Wave Plus Certified
  • Protocol: Sigma Serial API
  • Built-in 500 Series Z-Wave Module
  • Includes ZDK 6.5x Z-Wave Library
  • Field-upgradable Firmware
  • Supports 908.42 MHz (US) Z-Wave frequency
  • UPC: 610585164310
  • Z-NET Unit
  • AC Power Supply
  • Micro USB Power Cable
  • Quckstart guide
  • 1-year manufacturer's warranty
  • Works with all HomeSeer HS3-based systems (including HomeTrollers)
  • Requires wired Ethernet connection
  • Supports 908.42 MHz Z-Wave products
Customer Reviews
