{"product_id":"homeseer-z-net-pro-amazon-return","title":"HomeSeer Z-NET PRO (Amazon Returns)","description":"\u003ch3\u003e\u003cstrong\u003eZ-NET PRO – Next-Level Z-Wave \u0026amp; Zigbee Control, Anywhere on Your Network\u003c\/strong\u003e\u003c\/h3\u003e\n\u003cp\u003eTake your smart home to the next level with \u003cstrong\u003eZ-NET PRO\u003c\/strong\u003e, a powerful, network-connected controller designed to seamlessly send and receive Z-Wave and Zigbee commands through \u003cstrong\u003eHomeSeer\u003c\/strong\u003e or \u003cstrong\u003eHome Assistant\u003c\/strong\u003e. Whether you're managing a sprawling estate or a smart barn across the property, Z-NET PRO delivers fast, reliable performance—right where you need it.\u003c\/p\u003e\n\u003ctable width=\"100%\" cellpadding=\"4\" cellspacing=\"0\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd bgcolor=\"#F5F5F5\"\u003e\u003cspan color=\"#2B90D1\"\u003e\u003cspan color=\"#666666\"\u003e\u003cstrong\u003eAmazon Return\u003c\/strong\u003e \u003cspan\u003estock includes customer returns that have been returned to us. These units have been tested by us to ensure the Z-Wave and Zigbee chips initialize properly with a working HomeSeer system. All Amazon return items come with the original manufacturer's warranty and are also covered by our 30-day return policy.\u003c\/span\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3\u003e\n\u003cbr\u003e🔧 Key Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 📡\u003cstrong\u003e Dual-Protocol Control: Z-Wave + Zigbee\u003c\/strong\u003e - Run Z-Wave Plus v2 (800 series) and Zigbee 3.0 networks from a single device. Perfect for mixed ecosystems with lighting, sensors, switches, locks, and environmental devices without juggling multiple dongles. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 🏠 \u003cstrong\u003eNetwork Placement Where It Matters Most\u003c\/strong\u003e - Unlike USB radios that must sit next to your server or hub, Z-NET PRO connects via Ethernet or Wi-Fi, letting you place it centrally in your home or closer to devices for dramatically improved Z-Wave and Zigbee performance. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 📶 \u003cstrong\u003eStronger Meshes, Fewer Dropouts\u003c\/strong\u003e - Z-Wave 800 series provides longer range, faster communication, and improved reliability | Zigbee 3.0 offers responsive control and efficient mesh networking for sensors and lighting Better placement + modern radios = a faster, more stable smart home. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 🔐 \u003cstrong\u003eModern Security \u0026amp; Easy Device Inclusion\u003c\/strong\u003e - Supports Z-Wave S2 Security, SmartStart, and Network-Wide Inclusion, along with standard Zigbee pairing, ensuring compatibility with today’s devices and secure onboarding. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 🔄 \u003cstrong\u003eDesigned for Advanced Automation Platforms\u003c\/strong\u003e - Built for HomeSeer HS4 and Home Assistant, allowing you to centralize automation logic while keeping radios off your main system for improved stability. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\n\u003cspan class=\"a-list-item\"\u003e 🧠 \u003cstrong\u003eSimple Web-Based Setup \u0026amp; Monitoring\u003c\/strong\u003e - A built-in web interface and status LEDs make setup, configuration, and troubleshooting straightforward—no fragile USB connections or trial-and-error placement. \u003c\/span\u003e\u003cstrong\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003e🌍 Global Compatibility\u003c\/h3\u003e\n\u003cp\u003eNo matter where you live, Z-NET PRO is ready to work for you. Zigbee 3.0 uses the globally standardized 2.4 GHz band, and the Z-Wave module supports multiple international frequencies. Whether you're in the \u003cstrong\u003eUS, Canada, Europe, Australia, Japan, China, or beyond\u003c\/strong\u003e, setup is simple via \u003cstrong\u003eZ-Wave Plus\u003c\/strong\u003e or \u003cstrong\u003eZWaveJS UI\u003c\/strong\u003e settings in your preferred smart home platform.\u003c\/p\u003e\n\u003ch3\u003e⚙️ Tech Specs\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eZ-Wave Plus v2 800 Series Long Range Technology\u003c\/li\u003e\n\u003cli\u003eZigbee 3.0 EmberNet Technology\u003c\/li\u003e\n\u003cli\u003eField-upgradable Firmware\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003e📦 What’s in the Box?\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eZ-NET PRO Controller\u003c\/li\u003e\n\u003cli\u003eAC Power Supply\u003c\/li\u003e\n\u003cli\u003eEthernet Cable\u003c\/li\u003e\n\u003cli\u003eQuick Start Guide Card\u003c\/li\u003e\n\u003cli\u003e1-Year Manufacturer’s Warranty\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003e🧰 Requirements\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eCompatible with HomeSeer HS4 systems using Z-Wave Plus \u0026amp; Zigbee Plus plugins\u003c\/li\u003e\n\u003cli\u003eCompatible with Home Assistant via ZWave JS UI \u0026amp; ZHA or Zigbee2MQTT\u003c\/li\u003e\n\u003cli\u003eNot compatible with legacy HomeSeer v3\/v4 Z-Wave plugins\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e","brand":"HomeSeer","offers":[{"title":"Default Title","offer_id":47374210564271,"sku":"Z-NET-PRO-A","price":119.97,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1248\/3803\/files\/Z-NET-PRO-Box.jpg?v=1771969528","url":"https:\/\/shop.homeseer.com\/products\/homeseer-z-net-pro-amazon-return","provider":"HomeSeer","version":"1.0","type":"link"}
