{"product_id":"homeseer-z-net-pro-open-box","title":"HomeSeer Z-NET PRO (OPEN BOX)","description":"\u003ch3 data-end=\"161\" data-start=\"85\"\u003e\u003cstrong data-end=\"161\" data-start=\"85\"\u003eZ-NET PRO – Next-Level Z-Wave \u0026amp; Zigbee Control, Anywhere on Your Network\u003c\/strong\u003e\u003c\/h3\u003e\n\u003cp data-end=\"524\" data-start=\"163\"\u003eTake your smart home to the next level with \u003cstrong data-end=\"220\" data-start=\"207\"\u003eZ-NET PRO\u003c\/strong\u003e, a powerful, network-connected controller designed to seamlessly send and receive Z-Wave and Zigbee commands through \u003cstrong data-end=\"350\" data-start=\"338\"\u003eHomeSeer\u003c\/strong\u003e or \u003cstrong data-end=\"372\" data-start=\"354\"\u003eHome Assistant\u003c\/strong\u003e. Whether you're managing a sprawling estate or a smart barn across the property, Z-NET PRO delivers fast, reliable performance—right where you need it.\u003c\/p\u003e\n\u003ctable width=\"100%\" cellpadding=\"4\" cellspacing=\"0\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd bgcolor=\"#F5F5F5\"\u003e\u003cspan color=\"#2B90D1\"\u003e\u003cspan color=\"#666666\"\u003e\u003cstrong\u003eOPEN BOX\u003c\/strong\u003e \u003cspan\u003estock includes customer returns that have been opened. These units are in good shape but may have slight cosmetic blemishes. All open box items come with the original manufacturer's warranty and are also covered by our 30-day return policy.\u003c\/span\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3 data-end=\"550\" data-start=\"531\"\u003e\n\u003cbr\u003e🔧 Key Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 📡\u003cstrong\u003e Dual-Protocol Control: Z-Wave + Zigbee\u003c\/strong\u003e - Run Z-Wave Plus v2 (800 series) and Zigbee 3.0 networks from a single device. Perfect for mixed ecosystems with lighting, sensors, switches, locks, and environmental devices without juggling multiple dongles. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 🏠 \u003cstrong\u003eNetwork Placement Where It Matters Most\u003c\/strong\u003e - Unlike USB radios that must sit next to your server or hub, Z-NET PRO connects via Ethernet or Wi-Fi, letting you place it centrally in your home or closer to devices for dramatically improved Z-Wave and Zigbee performance. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 📶 \u003cstrong\u003eStronger Meshes, Fewer Dropouts\u003c\/strong\u003e - Z-Wave 800 series provides longer range, faster communication, and improved reliability | Zigbee 3.0 offers responsive control and efficient mesh networking for sensors and lighting Better placement + modern radios = a faster, more stable smart home. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 🔐 \u003cstrong\u003eModern Security \u0026amp; Easy Device Inclusion\u003c\/strong\u003e - Supports Z-Wave S2 Security, SmartStart, and Network-Wide Inclusion, along with standard Zigbee pairing, ensuring compatibility with today’s devices and secure onboarding. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\u003cspan class=\"a-list-item\"\u003e 🔄 \u003cstrong\u003eDesigned for Advanced Automation Platforms\u003c\/strong\u003e - Built for HomeSeer HS4 and Home Assistant, allowing you to centralize automation logic while keeping radios off your main system for improved stability. \u003c\/span\u003e\u003c\/li\u003e\n\u003cli class=\"a-spacing-mini\"\u003e\n\u003cspan class=\"a-list-item\"\u003e 🧠 \u003cstrong\u003eSimple Web-Based Setup \u0026amp; Monitoring\u003c\/strong\u003e - A built-in web interface and status LEDs make setup, configuration, and troubleshooting straightforward—no fragile USB connections or trial-and-error placement. \u003c\/span\u003e\u003cstrong\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3 data-end=\"1371\" data-start=\"1344\"\u003e🌍 Global Compatibility\u003c\/h3\u003e\n\u003cp data-end=\"1741\" data-start=\"1373\"\u003eNo matter where you live, Z-NET PRO is ready to work for you. Zigbee 3.0 uses the globally standardized 2.4 GHz band, and the Z-Wave module supports multiple international frequencies. Whether you're in the \u003cstrong data-end=\"1638\" data-start=\"1580\"\u003eUS, Canada, Europe, Australia, Japan, China, or beyond\u003c\/strong\u003e, setup is simple via \u003cstrong data-end=\"1675\" data-start=\"1660\"\u003eZ-Wave Plus\u003c\/strong\u003e or \u003cstrong data-end=\"1693\" data-start=\"1679\"\u003eZWaveJS UI\u003c\/strong\u003e settings in your preferred smart home platform.\u003c\/p\u003e\n\u003ch3 data-start=\"1883\" data-end=\"1900\"\u003e⚙️ Tech Specs\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eZ-Wave Plus v2 800 Series Long Range Technology\u003c\/li\u003e\n\u003cli\u003eZigbee 3.0 EmberNet Technology\u003c\/li\u003e\n\u003cli\u003eField-upgradable Firmware\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3 data-start=\"1748\" data-end=\"1773\"\u003e📦 What’s in the Box?\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli data-start=\"1777\" data-end=\"1799\"\u003eZ-NET PRO Controller\u003c\/li\u003e\n\u003cli data-start=\"1777\" data-end=\"1799\"\u003eAC Power Supply\u003c\/li\u003e\n\u003cli data-start=\"1777\" data-end=\"1799\"\u003eEthernet Cable\u003c\/li\u003e\n\u003cli data-start=\"1777\" data-end=\"1799\"\u003eQuick Start Guide Card\u003c\/li\u003e\n\u003cli data-start=\"1777\" data-end=\"1799\"\u003e1-Year Manufacturer’s Warranty\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3 data-start=\"1996\" data-end=\"2015\"\u003e🧰 Requirements\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eCompatible with HomeSeer HS4 systems using Z-Wave Plus \u0026amp; Zigbee Plus plugins\u003c\/li\u003e\n\u003cli\u003eCompatible with Home Assistant via ZWave JS UI \u0026amp; ZHA or Zigbee2MQTT\u003c\/li\u003e\n\u003cli\u003eNot compatible with legacy HomeSeer v3\/v4 Z-Wave plugins\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e","brand":"HomeSeer","offers":[{"title":"Default Title","offer_id":46792382677167,"sku":"Z-NET-PRO-OB","price":124.97,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1248\/3803\/files\/Z-NET-PRO-Box.jpg?v=1771969528","url":"https:\/\/shop.homeseer.com\/products\/homeseer-z-net-pro-open-box","provider":"HomeSeer","version":"1.0","type":"link"}
