Menu
Cart 0
HomeSeer Z-NET Remote Z-Wave Interface (US)
  • $ 149.95
Z-NET is a remote network-based Z-Wave interface for use with HomeSeer home automation systems. Since Z-NET is IP-enabled, it may be installed anywhere a network connection is available. Z-NET supports Network Wide Inclusion (NWI) for easy pairing of Z-Wave products. Multiple Z-NETs may be used together with any HomeSeer system for a centrally managed, muti-network installation; ideal for home owners with secondary residences or outbuildings (pool houses, barns, workshops, servants' quarters, etc).
  • Remote Z-Wave Interface for use with HomeSeer Software and HomeTrollers
  • Supports Z-Wave Plus (and older) Products
  • Ethernet (and WiFi) Connections Allow for Optimal Positioning in Home
  • Supports Network Wide Inclusion (NWI) for Easy Product "Pairing"
  • May be Used with Other Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
  • Includes Highly Optimized Antenna for Superior Range and Performance
  • Includes Easy to Use Web-Based Management Features
  • Provides Easy Upgrade Path from Z-Trollers, Z-Sticks, SmartSticks and Most Other Z-Wave Interfaces
  • Case Includes Keyhole slots for wall mounting (with your hardware)
  • Z-Wave Plus Certified
  • Protocol: Sigma Serial API
  • Built-in 500 Series Z-Wave Module
  • Includes ZDK 6.5x Z-Wave Library
  • Field-upgradable Firmware
  • Supports 908.42 MHz (US) Z-Wave frequency
  • UPC: 610585164310
  • Z-NET Unit
  • AC Power Supply
  • Micro USB Power Cable
  • Quckstart guide
  • 1-year manufacturer's warranty
  • Works with all HomeSeer HS3-based systems (including HomeTrollers)
  • Supports 908.42 MHz Z-Wave products
  • Reviews
Customer Reviews
Based on 30 reviews Write a review
