Menu
Cart 0
HomeSeer HomeTroller-SEL PRO Smart Home Hub
  • $ 699.95
HomeTroller-SEL Is Our Premium Grade PRO Series Home Controller. It Combines The Speed & Reliability Of Locally Managed Automation With The Power Of Cloud-Managed Services. Hometroller-SEL Is Powered By HS3 Home Automation Software And Includes Enough Available Ports To Satisfy Virtually Any Automation Need.
  • Home Controller with HS3 Software (SEL PRO edition includes HS3PRO)
  • Controls Light Switches, Thermostats, Door Locks, Garage Doors, Water Valves, Energy Monitors, Environmental Sensors, Cameras and More
  • Includes HS3Touch Designer Mobile App Design Software (reg $299.95)
  • Includes Z-Seer+ Z-Wave diagnostics Software (reg $39.95)
  • Includes Z-Flash Z-Wave OTA Firmware Updater (reg $29.95)
  • Includes Free HomeSeer Mobile app for Apple and Android Devices
  • Includes Free MyHS Remote Access Service
  • Supports All Linux Plug-ins (Drivers)
  • Works with Amazon Alexa & Google Home Assistant Devices
  • Directly Supports Google Voice Control from any Android Device
  • IFTTT Compatible – Works with Hundreds of Web Products, Apps and Services
  • Can issue spoken messages for alerts, announcement and reminders
  • Fully Customizable Email and Text Alerts
HomeTrollers process all your automation locally, ensuring the highest level of reliability and performance. You won't experience the "delays" that are common with Internet-reliant solutions like typical 'smart hubs' and 'gateways'..
Safe & Secure
Every HomeTroller is designed to store all your sensitive information right there at home, never in the cloud. This helps to prevent hackers and prying eyes from seeing your personal data and custom home automation schedules.
Internet-Independent
Our MyHS web service simplifies the process of controlling your home remotely but is not required to automate your home. Your HomeTroller will continue to control your home 24/7, even when the internet is down or there's a web service outage.
HomeTrollers are designed to work with thousands of products from hundreds of manufactures using most popular home automation technologies. With HomeSeer, your imagination is your only limitation!
Amazon Echo / IFTTT / Google Home
Leverage the latest technology with your HomeSeer-powered home! Use Amazon's popular 'Echo' or a Google Home device to control your home by voice and create IFTTT 'Recipes' that integrate with more than 300 web products, apps and services from around the world!
  • Control Software: HS3
  • OS: Linux
  • CPU: Intel Celeron N2807 CPU (1.58 GHz, 2 core)
  • RAM: 4 GB
  • Boot Time: < 20 Seconds
  • Storage: 32 GB SSD
  • Ports: LAN, 3x USB, HDMI, VGA, Split Audio
  • HT-SEL unit with embedded HS3PRO
  • Universal Power Supply with Plug Adapters
  • Z-Wave interface required for use with Z-Wave
  • CM15a required for use with X10
  • Smarthome 2413U PLM required for use with Insteon
  • Internet Connection
Customer Reviews
