Menu
Cart 0
HomeSeer HomeTroller Zee S2 (US) Home Automation Controller
  • $ 99.98
  • BLACK MAY
HomeTroller Zee S2 Is An Advanced Home Controller. It Combines The Speed & Reliability Of Locally Managed Automation With The Power Of Cloud-Managed Services. The Unit Is Powered By HS3-Pi Home Automation Software And It Supports Enough Smart Home Devices To Satisfy All But The Most Demanding Automation Needs.
  • Home Controller with HS3-Pi3 Software
  • Controls Light Switches, Thermostats, Door Locks, Garage Doors, Water Valves, Energy Monitors, Environmental Sensors, Cameras and More
  • Built In Z-Wave Radio (US edition only)
  • Includes Free HomeSeer Mobile app for Apple and Android Devices
  • Includes Free MyHS Remote Access Service
  • Supports Your Choice of Up to 5 Linux Plug-ins (including pre-installed Z-Wave plug-in).
  • Works with Amazon Alexa & Google Home Assistant Devices
  • Directly Supports Google Voice Control from any Android Device
  • IFTTT Compatible – Works with Hundreds of Web Products, Apps and Services
  • Can issue spoken messages for alerts, announcement and reminders
  • Fully Customizable Email and Text Alerts
    HomeTrollers process all your automation locally, ensuring the highest level of reliability and performance. You won't experience the "delays" that are common with Internet-reliant solutions like typical 'smart hubs' and 'gateways'.
    Safe & Secure
    Every HomeTroller is designed to store all your sensitive information right there at home, never in the cloud. This helps to prevent hackers and prying eyes from seeing your personal data and custom home automation schedules.
    Internet-Independent
    Our MyHS web service simplifies the process of controlling your home remotely but is not required to automate your home. Your HomeTroller will continue to control your home 24/7, even when the internet is down or there's a web service outage.
    HomeTrollers are designed to work with thousands of products from hundreds of manufactures using most popular home automation technologies. With HomeSeer, your imagination is your only limitation!
    Amazon Echo / IFTTT / Google Home
    Leverage the latest technology with your HomeSeer-powered home! Use Amazon's popular 'Echo' or a Google Home device to control your home by voice and create IFTTT 'Recipes' that integrate with more than 300 web products, apps and services from around the world!
    • CPU: ARM Cortex-A53 CPU (1.2 GHz, 4 core)
    • RAM: 1 GB
    • Storage: 8 GB SD
    • 4 USB Ports
    • LAN Port
    • HDMI Port
    • Linux OS
    • Includes built-in Z-Wave Plus certifed interface (US)
    • Built-in WiFi
    • AC Power Adapter: c(UL)us approved, 100-240v, 50/60Hz in, 5v 1a out, US style plug
    • Unit Dimensions: 4.4" x 3.8" 1" (113mm x 97mm x 27mm)
    • 3 watt power consumption
    • Works with your choice of up to 5 software plug-ins (drivers)
    • HomeTroller Zee S2 unit with built-in Z-Wave interface (US)
    • AC Power Adapter with Micro USB Cable
    • Ethernet Cable
    • Rubber Feet
    • Quick Start Guide
    • Internet Connected Router
    Customer Reviews
    Based on 41 reviews Write a review
