HomeSeer HS-CAM-I Indoor Pan & Tilt WiFi Security Camera
HS-CAM-I is a high resolution (1080P) indoor WiFi security camera with pan & tilt features. The unit is easy to set up and works nicely with all HomeSeer smart home software & hubs.
Features
- Pan & Tilt Operation
- 1080P Resolution
- WiFi Connectivity
- Night Vision
- IR Cut Filter
- Supports ONVIF & RTSP
- Works With HomeSeer Smart Home Software & Hubs
Operation
Pair with your WiFi network and follow the install guide to configure with your HomeSeer system. Video will appear on Cameras tab in HomeSeer Mobile.
- Resolution: 1080P (1920 x 1080)
- Lens: 3.6mm
- Pan & Tilt Range: 240° (H) x 60° (V)
- Night Vision Range: 20 ft | 6 m
- WiFi: 802.11 b/g/n (2.4 GHz)
- Optional Storage: Up to 128 GB MicroSD
- Power: DC 5V 6W
- Dimensions: 3.1 x 3.1 x 4.3" | 79.5 x 79.5 x 110mm
- HS-CAM-I Camera
- AC Power Adapter
- Mounting Bracket
- Mounting Screws & Plaster Anchors
- User Guide
- HomeSeer System Running HS3 software v3.0.0.548 (or later) & HomeSeer Mobile v1.1.0-99 (or later)
Customer Reviews
Based on 4 reviews
Write a review
