Menu
Cart 0
HomeSeer HS-CAM-O Outdoor Security Camera
  • $ 39
  • 🎄 HOLIDAY SALE!
📦 FREE Shipping on orders of $200+
Outdoor WiFi / Ethernet Security Camera
HS-CAM-O is a high resolution (1080P) outdoor security camera that connects to your home network via Ethernet or WiFi. The unit is easy to set up and works nicely with all HomeSeer smart home software & hubs.
Features
  • 1080P Resolution
  • Ethernet or WiFi Connectivity
  • Night Vision
  • IR Cut Filter
  • Supports ONVIF & RTSP
  • Weather Proof Housing
  • Works With HomeSeer Smart Home Software & Hubs
  • Does not feature Power over Ethernet (PoE)
Operation
Pair with your WiFi network or connect to your wired Ethernet network and follow the install guide to configure with your HomeSeer system. Video will appear on Cameras tab in HomeSeer Mobile.
  • Resolution: 1080P (1920 x 1080)
  • Lens: 4mm
  • Sensor: 1/2.7" CMOS
  • Night Vision Range: 80 ft | 25 m
  • WiFi: 802.11 b/g/n (2.4 GHz)
  • Optional Storage: Up to 128 GB MicroSD
  • Weather Rating: IP66
  • Power: DC 12V 7W (10 ft)
  • Dimensions: 7.1 x 2.6 x 2.6" | 180 x 67 x 67mm
  • FOV: 100°
  • HS-CAM-O Camera
  • AC Power Adapter
  • WiFi Antenna
  • Ethernet Cable
  • Mounting Template Sticker
  • Mounting Screws & Plaster Anchors
  • Cable Caps
  • User Guide
  • HomeSeer System Running HS3 software v3.0.0.548 (or later) & HomeSeer Mobile v1.1.0-99 (or later)
    Customer Reviews
    Based on 2 reviews Write a review
