Menu
Cart 0
HomeSeer HS-FC200+ Z-Wave Plus RGB Smart Fan Speed Controller Switch - USED
  • $ 34.95
  • FALL SALE
Z-Wave Fan Control Switch
What makes our Z-Wave smart fan control switch better? HS-FC200+ has (4) LED indicators that may be programmed to glow or blink different colors when things happen in your home and you can launch automations by tapping the paddle multiple times.
  • Supports 3 or 4-speed fan loads
  • Includes 4 individually controllable RGB LED status indicators
  • Color & blink status of LED indicators are controlled with Z-Wave commands (patent pending)
  • Support multi-tap and press & hold event triggers up to 5 taps (14 possible triggers)
  • Supports instant status when controlled locally
  • Compatible with HomeSeer (and many other) home controllers
  • Supports S2 Security
  • Easy 'screw terminal' installation
  • Works with HS-WA100+ wall companion for 3-way, 4-way and 5-way circuits
  • Includes Z-Wave signal repeater feature
Operation
Once installed, HS-FC200+ works like any other multi-speed conventional fan controller. However, add it to any HomeSeer system and you'll unleash these advanced features!
RGB LED Indicators
In normal mode, LED indicators glow to reflect the on/off/dim status of each circuit using a palette of 7 possible colors. Normal mode colors can be set once and left or can be programmed to change every day or on holidays, birthdays and other special events. For example, you can program dimmers to glow green and red on holidays
In status mode, individual LEDs can be controlled to reflect the status of nearly anything in the home. For example, if it's after midnight and the garage door was left open, the 3rd LED on all the bedroom dimmers can be programmed to glow yellow (or any color). If a smoke alarm goes off, all LEDS on all dimmers can blink red. If no status conditions are active, wall switches automatically return to normal mode.
Multi-tap Triggers
  • Press top or bottom of paddle once - turns attached load on or off and can also trigger  2 HomeSeer events
  • Press & hold top or bottom of paddle - dims attached load and can also trigger 2 HomeSeer events
  • Press top or bottom of paddle 2, 3, 4, or 5 times - triggers up to 8 more different HomeSeer events
Videos
  • Compatible with US Z-Wave networks (908 MHz)
  • 120 VAC, 60Hz
  • Supports fan loads up to 2.5 amps
  • Supports Z-Wave Plus features
  • Supports Z-Wave S2 security
  • cUL, FCC, Z-Wave Plus certified
  • Color: White.
Important
The special RGB and multi-tap features of this fan controller are fully supported by HomeSeer systems. SmartThings users may also take advantage of these features using a special device handler (for HS-WD200+). If you're using another brand of controller, contact HomeSeer for assistance.
On HomeSeer systems, simple event actions can be used to set the normal mode color and the individual LED status color (and blink).
Any controller that supports the Z-Wave configuration class may be used to set color options.
Return Information
  • Fan controllers with tabs broken off cannot be returned for a refund but may be returned for an exchange. Contact HomeSeer Customer Service for assistance.
  • 2-year warranty
Condition
USED stock includes customer returns that have been opened and installed. These units are in good shape but may have cosmetic blemishes and may also be missing hardware. All used items come with the original manufacturer's warranty and are also covered by our 30-day return policy.
Customer Reviews
