Menu
Cart 0
HomeSeer HS-WA100+ Companion Switch 3-Pack
  • $ 51.17
  • SALE
3-Way Companion Switch 3-Pack
HS-WA100+ is a wired (non-RF) 3-way wall companion switch that provides full featured remote control of HomeSeer Z-Wave smart dimmers & switches. HS-WA100+ requires only a traveler and neutral wire for installation. This bundle includes 3 companion switches.
  • Wired (non-RF) 3-way companion switch for use with HomeSeer Wall Dimmers & Switches
  • Supports ON - OFF - DIM functions of the connected load switch or dimmer
  • Supports Multi-Tap event triggers of the connected load switch or dimmer
  • May be paired with 1 or 2 more HS-WA100+ companions for 4-way or 5-way operation
  • Easy 'screw terminal' installation
  • Note: HS-WA100+ is not a stand alone switch and will not control a load by itself
Operation
Once installed, HS-WA100+ works like any other paddle-style switch and will remotely control the attached load switch with on-off-dim functions. Additionally, the HS-WA100+ will access the built-in features of HomeSeer load switches including the following:
  • Press top or bottom of paddle once - prompts appropriate load switch to turn attached load on or off
  • Press top or bottom of paddle multiple times - prompts appropriate load switch to trigger multiple different HomeSeer events.
  • Press & hold top or bottom of paddle - prompts appropriate load switch to dim attached load up or down and may also be used to trigger two more different HomeSeer events
  • Compatible with HomeSeer 100 & 200 series dimmers and switches
  • 120 VAC, 60Hz
  • cUL certified
  • May be paired with multiple HS-WA100+ companions for 3-way, 4-way & 5-way use
  • Color: White. Almond color kit available.
Important
This is not a stand-alone switch and will not control a load directly!
  • Requires standard 3-way electrical wiring (with traveler wire)
  • Must be used with HomeSeer 100 or 200 series wall switches or dimmers
Customer Reviews
Based on 3 reviews Write a review
