Menu
Cart 0
HomeSeer HS-WA100+ Wired 3-way Companion Switch for HomeSeer Dimmers & Switches - OPEN BOX
  • $ 19.97
  • 🎄 Holiday Sale!
📦 FREE US Shipping on orders of $200+
3-Way Companion Switch
HS-WA100+ is a wired (non-RF) 3-way wall companion switch that provides full featured remote control of HomeSeer Z-Wave smart dimmers & switches. HS-WA100+ requires only a traveler and neutral wire for installation.
  • Wired (non-RF) 3-way companion switch for use with HomeSeer Wall Dimmers & Switches
  • Supports ON - OFF - DIM functions of the connected load switch or dimmer
  • Supports Multi-Tap event triggers of the connected load switch or dimmer
  • May be paired with 1 or 2 more HS-WA100+ companions for 4-way or 5-way operation
  • Easy 'screw terminal' installation
  • Note: HS-WA100+ is not a stand alone switch and will not control a load by itself
Operation
Once installed, HS-WA100+ works like any other paddle-style switch and will remotely control the attached load switch with on-off-dim functions. Additionally, the HS-WA100+ will access the built-in features of HomeSeer load switches including the following:
  • Press top or bottom of paddle once - prompts appropriate load switch to turn attached load on or off
  • Press top or bottom of paddle multiple times - prompts appropriate load switch to trigger multiple different HomeSeer events.
  • Press & hold top or bottom of paddle - prompts appropriate load switch to dim attached load up or down and may also be used to trigger two more different HomeSeer events
  • Compatible with HomeSeer 100 & 200 series dimmers and switches
  • 120 VAC, 60Hz
  • cUL certified
  • May be paired with multiple HS-WA100+ companions for 3-way, 4-way & 5-way use
  • Color: White. Almond color kit available.
Important
This is not a stand-alone switch and will not control a load directly!
  • Requires standard 3-way electrical wiring (with traveler wire)
  • Must be used with HomeSeer 100 or 200 series wall switches or dimmers
Condition
Open Box stock includes customer returns that have been opened or new items with damaged packaging. Most items are in 'like new' condition but some may have slight cosmetic blemishes. All open box items come with the original manufacturer's warranty and are also covered by our 30-day return policy.
Customer Reviews
Based on 4 reviews Write a review
