HomeSeer HS-WS200+ Z-Wave Plus RGB Wall Switch - USED
📦 FREE Shipping on orders of $200+
Advanced Z-Wave Smart Switch
What makes our Z-Wave smart switch better? HS-WS200+ has an LED indicator that may be programmed to glow or blink different colors when things happen in your home and you can launch automations by tapping the paddle multiple times.
- Supports wireless on-off control of lighting and appliance loads
- Color & blink status of LED indicator is controlled with Z-Wave commands (patent pending)
- Supports multi-tap and press & hold event triggers up to 5 taps (14 possible triggers)
- Supports instant status when controlled locally
- Compatible with HomeSeer (and many other) home controllers
- Supports S2 Security
- Easy 'screw terminal' installation
- Works with Alexa and Google Home (hub required)
- Works with HS-WA100+ wall companion for 3-way, 4-way and 5-way circuits
- Includes Z-Wave signal repeater feature
Operation
Once installed, HS-WS200+ works like any other paddle-style switch and will turn the attached load on or off. However, add it to any HomeSeer system and you'll be able to trigger up to 14 different events!
RGB LED Indicator
In normal mode, the LED indicator glows to reflect the on/off status of each circuit using a palette of 7 possible colors. Normal mode colors can be set once and left or can be programmed to change every day or on holidays, birthdays and other special events. For example, you can program dimmers to glow green and red on holidays
In status mode, the LED can be controlled to reflect the status of nearly anything in the home. For example, if the front door is closed and locked, it can glow green. If the door is closed but not locked, it can glow yellow. If the door is open, it can blink red. If no status conditions are active, wall switches automatically return to normal mode.
Multi-tap Triggers
- Press top or bottom of paddle once - turns attached load on or off and can also trigger 2 HomeSeer events
- Press & hold top or bottom of paddle - triggers 2 HomeSeer events
- Press top or bottom of paddle 2, 3, 4, or 5 times - triggers up to 8 more different HomeSeer events
Video
- Compatible with US Z-Wave networks (908 MHz)
- 120 VAC, 60Hz
- 900 watt incandescent
- 200 watt LED / CFL
- 1/2 HP motor
- 1800 watts (15 amp) resistive
- Supports Z-Wave Plus features
- cUL, FCC, Z-Wave Plus certified
- Color: White. Almond color kit available.
- HS-WS200+ wall switch
- User Guide
- Screwless wall plate NOT included
Important
These features are supported by all HomeSeer systems, including HS3 software and HomeTroller controllers. If you're using another brand of controller, be sure to check with that manufacturer to see if the central scene features are supported.
- Z-Wave plug-in v3.0.1.190 or higher
Accessories
Return Information
- WS's with tabs broken off cannot be returned for a refund but may be returned for an exchange. If you find yourself in this situation, feel free to contact HomeSeer Customer Service.
- 2-year warranty
Condition
USED stock includes customer returns that have been opened and installed. These units are in good shape but may have cosmetic blemishes and may also be missing hardware. All used items come with the original manufacturer's warranty and are also covered by our 30-day return policy. |
