Menu
Cart 0
Intermatic CA3750 Z-Wave Contactor Module Electronic Assembly (NO ENCLOSURE)
  • $ 24.95
  • Sale
The CA3750 Multi-Voltage High Current Contactor Module is a Z-Wave™ enabled device which is fully compatible with any Z-Wave enabled network.
Note: This product includes the electronics assembly only (NO ENCLOSURE).
  • For Z-Wave Control of Larger Loads
  • Suitable for use with many Air Conditioners, Spas and Heaters
  • Multiple location ON/OFF control of contactor when used with wireless controls.
  • Multi-Voltage power supply 120, 208, 240 or 277 VAC
  • Field configurable outputs, 2 controllable SPST contacts or simultaneous DPST
  • Up-front activator switch always operates load, does not require central control system.
Specifications
  • Operating Temperature Range: -4°F (-20°C) to 140°F (60°C)
  • Power Consumption: 6.0W Maximum
  • Ratings: 120, 208, 240, 277VAC, 50/60Hz 6600 Watts
  • 30 A Resistive; 5500VA 25 A Inductive; 5540 Watts
  • 20 A @ 277VAC Ballast; 4400 Watts 20 A Tungsten;
  • 3HP @ 220VAC Motor
  • Connections: 1-Neutral/Line 2, 2-Line 1, 3 & 4 Contact 1, 5 & 6 Contact 2
  • Range: 50ft indoor
  • Frequency: 908.42 MHz
  • CA3750 Electronics Assembly Only (NO ENCLOSURE)
Customer Reviews
Based on 9 reviews Write a review
We Also Recommend
