Menu
Cart 0
Linear WO15Z Z-Wave Single Wall Outlet - HomeSeer Store
GoControl WO15Z Z-Wave Single Wall Outlet
  • $ 33.76
  • Duplex receptacle. 1 outlet Z-Wave controller, 1 outlet pass-through
  • On/Off control of lighting and appliances up to 15 amps
  • Doubles as a permanently installed Z-Wave repeater
Important Information
Linear's WO15Z is a Z-Wave controlled wall outlet (receptacle) that provides on/off control of just about any lighting or appliance load. One outlet is Z-Wave controlled; the other provides continuous pass through power.
Specifications
Color: White
Power: 120v / 60hz
Maximum Load - incandescent: 600, resistive: 15 amps, motor: 1/2 horsepower
Signal (Frequency) - 908.42 MHz
Range - Up to 100 feet line of sight between the Controller and /or the closest Z-Wave Device.
Z-Wave Version 4.5x
Network Inclusion
WD1000Z-1 Switch
Instruction Sheet
Trim Plate
We Also Recommend
