Mark Sandler Insteon Software Plugin for HS3
HS4 users: This plugin was created for HS3 and should run on your HS4 system. However, the setup/config pages are not optimized for use on mobile devices. An HS4 version of the Insteon plugin is now available Here. |
This plugin integrates Insteon products with Homeseer 3. It supports most of Smarthome Insteon devices, and a few Smartenit EZIO devices. Insteon Thermostats, and other Smartenit devices are support through secondary plugins. The IRLinc Transmitter is not currently supported. Other unsupported devices may be integrated using the external script support. Check the support forum for existing external scripts. See the following post for a comparison to the HS Insteon plugin
- Troubleshoot communications issues
- Register Devices
- Create Insteon Groups (aka Scenes
- Manage Device and Group Links
- Program special features (backlighting, LED flashing, beeping, etc) of devices
- Create triggers on Insteon messages
- Reset and Reprogram the Interface
- PLM 2412S, PLM 2412U, PLM 2413S, PLM 2413U, USB Adapter 2448A7, and the Insteon Hub (except Hub Pro).
Customer Reviews
Based on 47 reviews
Write a review
