Menu
Cart 0
Schlage Connect BE469NX-CAM-605 Bright Brass Camelot Touchscreen Deadbolt:HomeSeer Store
  • $ 178.97
  • SALE
The touchscreen Schlage deadbolt lock features modern touchscreen buttons and a motorized deadbolt. Commands can be sent from Homeseer to unlock or lock the deadbolt remotely. Note: All BE469NX models include an audible tamper alarm. If you do not need this feature, consider the lower priced BE468NX models instead.
  • ANSI Grade 1 Highest Residential Security
  • Durable Resistive Touchscreen with matte finish to protect against fingerprints and smudges
  • Anti-pick shield protects against lock tampering
  • Strong motorized bolt automatically locks and unlocks when a user code is entered
  • Build-in Alarm Technology senses movement of the door and alerts homeowners with an audible alert
  • Select between three alerts- activity, tamper or forced entry alert- and customized to meet fit your security needs
  • Lock or unlock your door from anywhere with your cell phone
  • Schedule lock codes to be active only on certain days at specific times
  • Receive text alerts when an alarm triggers or when specific codes are entered at the lock
  • Holds up to 30 user codes
  • Easy installation with just a screwdriver- no wiring required
Specifications
  • Applications: Residential single family doors
  • Certifications: Grade 1 ANSI/BHMA certified
  • Keying: 5-pin tumbler, C Keyway, 1 key included
  • Door range: 1-3/8” to 1-3/4” (35mm-44mm) standard
  • Operating Temperatures: Outside escutcheon: -35C to 66C, Inside escutcheon: -10C to 49C
  • Deadbolt Lock
  • Installation Manual
  • User Guide
  • 4xAAA Batteries
Customer Reviews
Based on 5 reviews Write a review
We Also Recommend
