Menu
Cart 0
Schlage Connect BE468NX-CAM-605 Bright Brass Camelot Touchscreen Deadbolt
  • $ 146.30
  • Sale
The touchscreen Schlage deadbolt lock features modern touchscreen buttons and a motorized deadbolt. Commands can be sent from Homeseer to unlock or lock the deadbolt remotely. Note: BE468NX models do not include an audible tamper alarm. If you require this feature, purchase a BE469NX model instead.
  • ANSI A156.36-2010 Grade 2 Higher Security Rating
  • Smudge and Fingerprint Free with Durable Resistive Touchscreen
  • Durable Resistive Touchscreen with matte finish to protect against fingerprints and smudges
  • Anti-pick shield protects against lock tampering
  • 1 Year Battery Life with 4 AA Batteries Included
  • Strong motorized bolt automatically locks and unlocks when a user code is entered
  • Lock or unlock your door from anywhere with your cell phone
  • Schedule lock codes to be active only on certain days at specific times
  • Receive text alerts when an alarm triggers or when specific codes are entered at the lock
  • Holds up to 30 user codes
  • Easy installation with just a screwdriver- no wiring required
Specifications
  • Applications: Residential single family doors
  • Certifications: Grade 2 ANSI/BHMA certified
  • Keying: 5-pin tumbler, C Keyway, 1 key included
  • Door range: 1-3/8” to 1-3/4” (35mm-44mm) standard
  • Operating Temperatures: Outside escutcheon: -35C to 66C, Inside escutcheon: -10C to 49C
  • Deadbolt Lock
  • Installation Manual
  • User Guide
  • 4xAA Batteries
    We Also Recommend
