Menu
Cart 0
Schlage FE599-505 Z-Wave Lever Lock - Bright Brass:HomeSeer Store
  • $ 180.00
The Schlage Wireless Lever Lock allows the remote locking and unlocking of a door through a Z-wave network.
  • Schlage Wireless Keypad Locks can be added to a Z-Wave network within your home
  • Installation and set up are simple. When paired with the Schlage Bridge, the wireless keypad lock is securely connected to the Internet
  • Web-based access means greater peace of mind, no matter where you travel
  • Confirm the status of your Wireless Keypad Lock from anywhere with any Internet-enabled computer and most Internet-enabled cell phones
  • Uses 128 bit AES encryption for security
  • Remotely lock or unlock the door
  • Assign up to 19 personalized 4 digit codes for each member of your household to use at the door
  • Provides battery level status at the lock and via the web
  • Easily program Schlage LiNK to send automatic text or email updates so you’ll always know who’s home
Specifications
  • 3 Years of Battery life
  • 128 bit AES encryption
  • Supports Z-Wave Beaming technology
  • Lever Lock
  • Installation hardware
  • Instructions
  • Supported hardware/software. Please check that your system supports Z-Wave locks, many do not. These locks are supported with the HomeSeer software and controllers.
Comments / Notes
  • Note: The lock may be controlled directly by HomeSeer software without the LiNK bridge!
  • From HomeSeer, you can add/remove user codes using any web browser.
We Also Recommend
