SirMeili FireBoard Software Plugin for HS3
HS4 users: This plugin was created for HS3 and should run on your HS4 system. However, the setup/config pages are not optimized for use on mobile devices. |
Connects a FireBoard system with HS3 to create events based on the measurements from any/all probes.
- Imports FireBoard Meters (Battery, Wifi)
- Create Root Device For Each Probe (1 - 6)
- Per Channel Devices
- Alert Max Temperature
- Alert Min Temperature
- Alerts Enabled
- Alert Notify Method (App, Email, SMS)
- Current Temperature
- Current Session Name (On/Off) For Event Triggers based on Session Start
- Events can be created for any device
