Trane XR524 Z-Wave Thermostat
📦 FREE Shipping on orders of $200+
The Trane XR524 Z-Wave thermostat features a digital black and white touchscreen, offers control of one cooling and two heating stages. Remotely control and monitor your home’s temperature and reduce energy consumption through your smartphone, tablet, or PC. Note: The thermostat may be controlled directly with any HomeSeer HS3 system.
- Easy to install; most people install the Trane XR524 in 30 minutes or less
- 7 day programmable with up to 4 schedules per day
- Receive filter and maintenance reminders to help extend the life of your HVAC system
- Compatible with any conventional 24 volt control heating or cooling system
- Touchscreen Display
Specifications
- System Type: Standard (gas/electric) and heat pump
- Standard HVAC Systems: 2 stage heating and 1 stage cooling
- Heat Pump systems: 1 compressor heat with 1 stage aux heat and 1 stage cooling
- Power: 24 VAC from HVAC System
- Trane Thermostat
- Mounting hardware
- Instructions
- Thermostat requires 24VAC power
Comments / Notes
- Not for use with 120/240V electric baseboard heat
- Not for use with proprietary communicating systems
- Not for use with radiant floor heating systems
Customer Reviews
Based on 3 reviews
Write a review
