Menu
Cart 0
Trendnet TU-S9 USB to Serial Converter Cable:HomeSeer Store
  • $ 19.95
This USB to Serial converter allows you to connect a RS-232 serial device such as a modem to a USB port on your Desktop or Laptop PC. Compatible with HomeSeer Z-Troller and other serial devices.
  • Connect a RS-232 serial device such as a modem to a USB port on your computer
  • Compliant with USB 1.1 specifications
  • Supports RS-232 serial interface
  • Supports up to 500kbps data transfer rate
  • Detects USB suspend condition
  • Compliant with Windows 7/Vista/XP/2000/ME/98SE and Mac OS 10.1~10.6
  • Install as a standard Windows COM port, Full RS-232 modem control signals, RS-232 data signals; TxD, RxD, RTS, CTS, DSR, DTR, DCD, RI, GND
  • Supports BUS Power, no external power adapter required
  • Supports plug & play and easy Installation
  • 2-year limited warranty
  • Works on Linu
Specifications
  • Interface: USB 1.1 Type A RS-232 (9-pin) Male
  • Supported OS: Windows 7 (32/64-bit)/Vista (32/64-bit)/XP(32/64-bit)/2000/ME/98SE Mac OS 10.1~10.6, Ubuntu, Lubuntu, and Raspbian
  • Cable Length: 661mm (26in.)
  • Certification: CE, FCC
  • USB to Serial Adapter
  • Install Guide
  • Driver CD
We Also Recommend
